CTRL SHIFT K not working for one track
Hello folks,
Rookie here using ProTools. I have several voice-over audio tracks recorded and for the life of me when I select the track and press CTRL+Shift+K nothing happens, I do not get the prompt export box with all the options. I can select any other track and the export box comes up right away. Any ideas what I did wrong? How do I get also the export selected box for this track? Thanks in advance! |
Re: CTRL SHIFT K not working for one track
Try consolidating it first (Shift+alt+3) then try again :)
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1 |
I did try that and still had the same issue. Any other ideas?
Do your export from the CLIPS bin(not a fix, but at least a work-around)
How do I do that? Would you mind to post like a screenshot?
I was not doing something right... That did the trick. Thanks for the help.
Screen shots attached. First pic shows the arrow that opens the Clips Bin(when its open, the arrow will point the other way and will close the bin). Second pic shows clips that are selected(highlighted). Right-click on any selected clip(in the Clips Bin) will show the menu where the Export Clips as Files option is available. The shortcut you were/are using is fine for exporting 1 or 2 clips, but the Clips Bin makes exporting dozens of clips easier. Remember; the cool thing about digital is; there's 4 ways to do anything. The bad thing about digital is; there's 4 ways to do anything
Mod keys (opt, cmd, shift, ctrl) stopped working in PT 12.8.3 | sircletus | macOS | 0 | 04-10-2018 07:58 AM |
Deleted Regions CTRL + SHIFT + U | ReynaldoPena | Windows | 2 | 12-02-2012 07:18 PM |
Shift + Option + Record Enable not working with MIDI and Audio Track selected, why??? | enzomolinari | Pro Tools 9 | 0 | 07-20-2011 07:00 AM |
CTRL -> Shift drag | Nathan W. | Pro Tools TDM Systems (Mac) | 1 | 10-19-2009 03:29 PM |
Pressing Ctrl+Shift causes keyboard to malfunction | matt connolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-16-2006 07:09 PM |
