Old 07-19-2010, 08:20 PM
DarylBham DarylBham is offline
Default CORRECTION: Adat Device doesnt playback audio during Recording or Playback
I posted another scenario before, but it was incorrect... i just upgraded from Pro Tools 8.0.3 to 8.0.4. I am using a Digi 002 with a Presonus Digimax going into it thru ADAT. I found out that I can plug a mic directly into my Digi 002 and everything works fine, but if i go thru the Presonus Digimax, I can see the signal on that particular track, but cant hear anything thru the same exact Main Outputs(Analog 1 and 2). However, i did change the output to a Bus(Bus 1 and 2), and made a bus track(Bus Input 1 and 2) and the Outputs of the Bus are the Mains(Analog 1 and 2), then i can hear the signal thats being sent. Weird huh...
I have changed the clock to ADAT in the session as well. Is there a new setting now that PT has added, in order for me to hear the inputs from the ADAT?
Basically, its like my ADAT inputs cant be monitored directly from the Mains, where as, i must Bus them thru another track to hear them thru the mains. Also, i did check the I/O's and made sure that everything is still on default
Old 07-19-2010, 08:56 PM
cwsand's Avatar
cwsand cwsand is online now
Default Re: CORRECTION: Adat Device doesnt playback audio during Recording or Playback
Can you post a screen shot of your I/O and Mix Windows?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-19-2010, 08:57 PM
sure... i wish i would have saw this before i left the studio, but i will do it tomorrow when i get there
Old 07-20-2010, 08:13 AM
otobot otobot is offline
I have a similar problem with 8.04 LE and Digi 003 console.
When I create a new audio track or a bus and record or assign audio to it, I can see that audio is there in the track's meter, but nothing gets through to the assigned output (standard: Analog 1-2).
I have to re-assign the output (by choosing another output and changing back to the original output pair, or by simply re-choosing the original output pair), only then can the audio be heard.
Sounds strange?
Old 07-20-2010, 10:08 AM
yea, it does sound very similar to my issue... only mine is just happening with my ADAT inputs
Old 07-21-2010, 06:36 AM
Does re-assigning the output (instead of routing it to another bus like you described) also help on your end?
Old 07-21-2010, 06:51 AM
binty binty is offline
Did you press the record button on the audio track.
Old 07-21-2010, 08:01 AM
Next you'll ask if Pro Tools is started, right?
Old 07-21-2010, 03:56 PM
Ok, im uploading the Screenshots now... also, i tried to reinstall a couple of times, and when i restart, i get a Blue Screen... dont know what thats all about... like someone else said, i think the old drivers are hidden on there somewhere
Old 07-21-2010, 05:00 PM
here are the links to the screenshots:
http://i163.photobucket.com/albums/t...%20DUC/Bus.jpg
http://i163.photobucket.com/albums/t...0DUC/Input.jpg
http://i163.photobucket.com/albums/t...DUC/Insert.jpg
http://i163.photobucket.com/albums/t.../MixScreen.jpg
http://i163.photobucket.com/albums/t...DUC/Output.jpg
Midi M-Audio device only audible during record or playback davem1 Pro Tools 9 5 02-09-2012 06:30 PM
audio device underflow(-6085) during Playback M577 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-01-2008 07:16 AM
audio device underflow(-6085) during Playback M577 Pro Tools TDM Systems (Mac) 4 05-26-2008 04:38 AM
Audio Import....unable to aacquire playback device hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 03-22-2007 05:58 PM
audio playback device: major issue coolhunter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-23-2004 02:24 PM
