Looking for a simple drum pad, not grooves.
Hi people,
I am a new Mac and pro tools user and I am having a hard time figuring out and trying to find a simple midi plug in for use with pressure pads. I was previously using Studio One 2 and it had a built in plugin called Impact which was a simple layout for pads. It had 16 onscreen pad with preset sounds but I was able to add my own .wav files to use with my midi pads. I also use Drumwerks audio samples because they sound much much better than any "high quality" drum presets that are in most grooves. I all I want is some kind of MIDI pad controller/trigger that I can import my own audio files into, along with some basic velocity, pan, volume setting. If anyone knows how to help me I would absolutely appreciate it! |
Re: Looking for a simple drum pad, not grooves.
Well, if I understand what you are looking for then check out FXpansion Geist.
If you want a complete drum virtual instrument then check out BFD3, or Superior Drummer 2, or SSD4.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Kontakt is good for importing and mapping your own samples, though there is a bit of a learning curve with the Kontakt interface...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Reggae Drum Grooves | Artfuldodger | macOS | 9 | 03-12-2012 09:53 AM |
Simple drum machine on old 001 | Seltaeb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-14-2008 06:39 PM |
simple drum controller | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-17-2007 01:11 PM |
drum software w/ most tempo control on grooves | joemail75 | Virtual Instruments | 1 | 01-04-2007 12:24 PM |
Let's hear your drum tracks, samples and grooves! | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-28-2004 11:51 AM |
