Kontakt as Stand Alone Slave - no VEP Pro?
Greetings,
I have an ancient Mac Pro with PTHD 9 on it. I recently experimented with terror and finally bought Logic 9. I set up slaving Logic on a MacBook Pro which actually works pretty well. I really think Logic gets better performance on the ancient MacBook over the ancient Mac Pro….using the same plugs in Kontakt. Question…I know about VEP 5 Pro but isn't there an easy way to set up Kontakt in Stand Alone mode as a slave on my MacBook?(without Logic & or VEP Pro)? TIA! |
Re: Kontakt as Stand Alone Slave - no VEP Pro?
Never mind....got it.
can you share with us how to do it ?? or if not possible let us know that as well .. thx john
If you don't have VE Pro, you will need an audio output from the slave computer connected to an audio input on the master computer, and MIDI out from the master computer connected to MIDI in on the slave computer. If you are sending digital audio via SPDIF, ADAT, etc. from the slave to the master, you need to sync the word clock of the two computers.
Usually, an audio interface with built-in MIDI is the simplest way to do this. You can also use an ethernet MIDI program like ipMIDI or MidiOverLAN to handle MIDI between the computers, but IMO you might as well just use VEP if you are going to get a network involved.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Later that day, sorry checking in here late…yes, connect the two computers with an ethernet cable & set up a network using the IAC Driver in the MiDI Window of the Audio MIDI setup. (There's some youtube vids showing how to specifically)Like John Toolbox mentions above, if you're using two computers you'll need to return the audio of the computer with the stand alone Kontakt back into a couple of channels(or more) of Pro Tools and also like he says….just get VEPro, an amazing piece of software that makes the process pretty seamless and you don't need an extra audio interface with it.
Splurge $25-30 on a USB Vienna Key or Stenberg Key and Vienna will link you a 30 day, fully functioning demo of VEP Pro. It's what I did. You'll buy the software after that for sure though. |
Agree.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
You install the software on both, the key goes on the slave & you open up a VEP Server on the slave and open up a VEP RTAS plugin on an Instrument Channel on the Master, a pop up will come up and hit "connect". I just used a regular CAT5 Ethernet cable I had lying around. There's a slight learning curve to figuring out the MIDI channels and ins & out of how you want to route the stuff back & forth but even I was able to figure it out fairly quick.
Yah, obviously I guess you'd have to make sure that the software is good to go with your Winbox and that those synths can be loaded into VEP. It really is as advertised, pretty great software IMO.
PT presets from kontakt 4 not opening in kontakt 5 | table17 | Virtual Instruments | 0 | 02-06-2012 12:13 PM |
Can I trigger Kontakt Player Stand-alone from PT? | Farmer Dave | Pro Tools TDM Systems (Mac) | 4 | 05-18-2009 12:55 AM |
korg d1600 being slave a slave to pro tools | sbag | MIDI | 0 | 04-12-2007 06:50 AM |
Kontakt 2 Stand Alone vs RTAS, Kontakt vs Giga | ryan de topanga | Pro Tools TDM Systems (Mac) | 18 | 05-17-2005 06:36 AM |
