Old 07-17-2017, 07:10 AM
Sean Russell Sean Russell is offline
Default 12.8 "clip groups with embedded fades not supported for fade command"
"could not complete your request because clip groups with embedded fades are not supported for the fade command during record"
Anytime I'm in record, now, since updating to PT12.8 (vanilla), I'm finding there are a LOT of things I can't do (while recording).
You can't edit a clip group while recording.
You can't add a fade to a clip group while recording.
When did this start?
Anyone else seeing this?
Currently experiencing this weirdness on a 24 core cheese grater / OS 12.5 / PT 12.8 (v) - Apollo 16 / UAD 9.2 (everything current)
... but does it help the chorus?
Old 07-17-2017, 07:15 AM
john1192 john1192 is offline
Default Re: 12.8 "clip groups with embedded fades not supported for fade command"
when is the last time it worked the way you would like it to work ???
any system info .. mac, PC, etc ..
thx john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-17-2017, 07:19 AM
Before 12.8, I could edit clip groups, no worries, while recording passes. I do a lot of random editing while laying back long-form mixes.
I already added my system info -
This is happening in Mac OS 12.5 / PT 12.8 (v) - Apollo 16
Old 07-17-2017, 07:26 AM
so 12.7.1.733 ??? or an earlier version .. we do not know which version you came from .. i should have been more Specific ..
thank you john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-17-2017, 07:38 AM
After I updated from 12.7, sorry.
Now, running 12.8 on a vanilla mix rig via Apollo 16, I'm seeing this issue. It has appeared with 12.8 (v).
This system is pretty rock solid - no funky plugs, everything has been curated from proper installs and preferences flushed. It appears to be a new "feature"
Also -
I'm using PT11(v) on a mobile rig - no issues.
PT10 HD on multiple CPU's - no issues.
File Type: png Screen Shot 2017-07-17 at 9.56.20 AM.png (40.4 KB, 0 views)
Old 07-17-2017, 07:43 AM
Hmmmm it's not just clip groups - it's ANY CLIP in the timeline that's on the same track as a clip group - and the 'error' message only appears when trying to edit that track....
This is a weird one!
Old 07-17-2017, 07:48 AM
i am just doing some backups at the moment .. i will try this out when they are finished ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-17-2017, 08:10 AM
ok, i see this ..
1) if there are NO Fades in 12.8.0.864 you can Edit clip groups ..but if add fades you get the error ..
2) in 12.7.1.733 .. works fine .. i can add Fades and edit them
i will write this up on my end .. you might want to create a support case as well ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-17-2017, 08:25 AM
Aha ! It's not just me.
At least there's that. Saved me a complete re-install, and I've only just been using 12.8 in the last week, haha!
I'll create a support ticket.
Thankyou, John!
Old 07-17-2017, 09:04 AM
Thankyou, John!
your welcome .. hopefully they can get this into the next update .. !!! i passed this up my Food Chain as well ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Batch Fades with "F" key don't respect fade dialogue settings jeremiahmoore Post - Surround - Video 19 09-03-2017 10:13 AM
Separate clip creates short "fade out" PrimozVozelj Pro Tools 10 4 04-12-2016 04:36 AM
WTH is an "embedded fade"? (PT8 Elastic Audio error) jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-17-2015 04:15 AM
PT10 "sees" Eleven Rack as playback engine only (no editor window,embedded rigs,etc) locust_tree Eleven Rack 4 12-08-2014 03:16 PM
Cross fades named "Fade hKivuUYViZuiDjg" Mick F. Cantarella Pro Tools TDM Systems (Mac) 18 07-01-2002 03:27 PM
