Old 10-10-2020, 07:31 PM
ozzlvlosis ozzlvlosis is offline
Default Duplicated clip mirroring edit
All of a sudden when I duplicate a clip, when I edit the duplicated clip, the same edit happens on the original clip as if it's being mirrored. I just want to be able to edit the duplicate without the original being affected
Any suggestions?
Old 10-10-2020, 08:33 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Duplicated clip mirroring edit
MIDI Clip? Turn off Mirrored MIDI Editing...
akmedia.digidesign.com/support/docs/Pro_Tools_Reference_Guide_v11_3_83709.pdf#G41.1214 807
linkedin
Old 10-10-2020, 09:16 PM
Yes that was it thank you so much
Isue when dragging clip from clip bin to edit window silky38 Pro Tools 2019 3 11-04-2023 08:34 AM
Cannot Edit Clip Effects in PT 12.6 HD conleec Pro Tools 12 81 01-30-2017 07:55 PM
Issue dropping more than one clip into the Edit Window with Clip Transparency ON arb232 Pro Tools 12 0 02-10-2016 06:01 PM
Clip indicators in edit window P_J Pro Tools 11 4 10-17-2013 05:40 PM
Duplicated Clip is Missing Half a Beat completeidiot23 Pro Tools 10 1 08-05-2012 06:46 PM
