Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 12-29-2019, 03:55 PM
kirkbross's Avatar
kirkbross kirkbross is offline
Default PT session load time affected by what computer parts?
Geek question, but what component/s of a computer has / have the greatest effect on load time of a large Pro Tools session?
I fully realize that session load time is first and foremost directly related to the number of plugins, sample libraries, etc. in the session. Given that, I have the latest Mac Mini with the 6 core i7 and 32GB RAM and some of my large sessions take more than a full minute to load. Not the end of the world, but I am curious, purely from a geekery standpoint, if you could build an imaginary computer, which of the below would have the greatest impact on session load time?
1) striping the OS across a dozens of SSDs in RAID 0
2) striping all your audio and libraries across dozens of SSDs in RAID 0
3) having ten billion gigs of RAM
4) having ten billion 4GHz cores at your disposal
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave.
Old 12-29-2019, 04:17 PM
hakofred hakofred is offline
Default Re: PT session load time affected by what computer parts?
After i changed to a 1 terrabyte SSD harddisk, and dobbeled the ram, everything speeded significant up on my system!
I also use a extern SSD disk for the sessions and projects
Imac 21,5 late 2012, (upgraded 2018), i7 quad core 3,1 ghz 16 gb ram. Samsung Evo 850 SSD 1tb. Catalina 10.15.3, PT 2021.12, Waves Diamond ++. Native instruments komplete ultimate. Arturia Matrix 12v2. Mini V v3, Prophet v3, Air , Hammond B3x
etc...
Old 12-29-2019, 06:26 PM
BScout BScout is offline
Seems more of a thought exercise.
If given an adequate system, then it will be #2 (though you don't have to go that far -- you can saturate TB3 and/or PCIe bandwidth/lane limits with 4 NVMe drives and a good controller without even doing something stupid like RAID 0 but a more sensible RAID 5)
I say "adequate system" because if your cpu is poor or your RAM very limited, then you have other bottlenecks. Which is why I see this as a thought exercise.
"Excess RAM" can help after opening but not really during opening.
High clock CPU can help load times but lots of cores, not really. It's mostly a serial process so those other cores aren't helping.
Striping an OS over a RAID is just dumb and mostly not supported.
Old 12-29-2019, 07:04 PM
DontLetMeDrown DontLetMeDrown is offline
Honestly, when it comes to startup, Pro Tools just sucks compared to the competition. Seriously why tf in 2019 does it load every plugin at startup? It should only do that when the user chooses to scan in the preference menu like nearly every other DAW. I have over 500 plugins, so you can imagine how long my PT startup is even with an i7 loading everything from an NVMe drive.
Old 12-29-2019, 09:19 PM
kirkbross's Avatar
It is a thought exercise for sure.
This is old, from 2011 but a fun watch if you haven't seen it:
https://www.youtube.com/watch?v=eULFf6F5Ri8
Old 12-30-2019, 07:45 AM
john1192 john1192 is offline
toss the prefs and it makes it load everything again .. !!!! super slow yes
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-30-2019, 03:09 PM
What exactly are you looking at/worried by? Plugin load times themselves? Plugin loading/scanning affects Pro Tools application startup time not the session start up. Is it Pro Tools startup that is the issue? Or is it the session? Separate those things and be clear. If it's the session then it may be plugins pre-loading samples, maybe made worse by concurrently trying to pre-load huge sessions into dick cache? You can play around... try setting disk cache to normal, try setting VI samples to stream etc. Asking others to guess is likely not going to help. And then you can get more detailed using systems performance tools, looking at wether stuff appears pegged on a few cores or one core and or how much disk or memory is being beaten up.
And yes try trashing prefs and rebuilding stuff (horribly slow the first time) and see if that improves things.
Old 12-30-2019, 08:05 PM
kirkbross's Avatar
I'm not worried or concerned about anything really. It's just a thought experiment.
There exists an imaginary computer with an imaginary architecture that could load, for example, Hans Zimmer's largest session in under 1 second. I'm just wondering what the specs of that [imaginary] computer would be. i.e. what attributes (single core cycles, multi-core count, RAM speed, RAM amount, throughput, etc.) would be the key ingredient(s) to achieve that feat.
Heat is deactivated every time I load this session YYR123 Pro Tools 12 3 02-08-2016 07:27 AM
Computer Shut Down Screen when trying to load a session. AdamAMM macOS 7 10-18-2011 10:31 AM
session load time too long soundguy_2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-27-2008 08:19 AM
If I edit files after exporting to 2nd session, how is 1st session affected? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-02-2002 12:01 AM
