Old 11-11-2015, 08:39 PM
mesaone mesaone is offline
Default Delay Compensation on AUX tracks - automatic
I encountered something strange... Maybe I just encountered my own ignorance. Pro Tools HD 11.3.1.
Why is my AUX track being compensated by 544 samples in a 48 kHz project (image here), and 832 samples in a 192 kHz project (image here)? There's nothing there. It should read zero. Is delay compensation being measured for cascaded buses now? Each AUX track feeds a secondary AUX that feeds the main.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 11-11-2015, 10:21 PM
Emcha_audio's Avatar
Default Re: Delay Compensation on AUX tracks - automatic
Do you have any other plugin that are actually giving those levels of latency?
Manny.
Wave-T.com
Old 11-11-2015, 10:59 PM
No plug-ins. This just shows up when I feed a bus.
Old 12-21-2015, 07:37 AM
RiF RiF is offline
I am having the same issue. Aux tracks show a delay where no delay should be (around 1000 samples here).
And yes, I am feeding Aux's (say: Drum Bus) into Aux's (say: Drum and Parallel Compression Bus combined) into Aux's (say: Mix Bus).
And no, I am not using any delay-inducing plugin anywhere in the session.
I don't know when it appeared, but I am sure that on PT9, it hasn't been this way (just recently upgraded to PT11 and now to PT12).
Old 12-22-2015, 01:04 PM
RiF RiF is offline
I am still trying to find out where it comes from and how to re-produce it. mesaone, your session yields 0 samples of latency on my rig.
Then I though cross-referencing aux sends (aux 1 sends into aux 2 and vice verse) would be it, but it isn't. Then I found it in one session where deactivating that one send into an aux eliminated the delay, but still, I cannot reproduce it in a new session...
I keep trying.
Old 02-08-2016, 02:17 PM
RiF RiF is offline
I found out that Pro Tools (12) creates unusally high amounts of delay when aux sends point to "nowhere". Like when you send something to say Bus 3 and no other track, aux or sidechain input has this Bus 3 as an input.
On my system, the extra delay is about 1800 samples.
Old 02-08-2016, 03:26 PM
Huh, well my test session did not have a "bus to nowhere" as there was another Aux track receiving Bus 5, it just wasn't in the screenshot... I think. It's been awhile, I'll go back and check. I'll retry it, but this time set that Aux track output to a physical output and see what happens.
Old 02-09-2016, 12:35 AM
demodigi demodigi is offline
Yes, I confirm.
But I think it's just a display issue : Is there actually a delay ? => who knows as we can't listen to the signal. But I used to get other cases where delay comp display was wrong and there was actually no delay.
Your bus 5 must be terminated to the output "Main" (which I suppose is a physical output) so that ADC can properly be calculated otherwise you get "strange" delay comp value.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
Old 02-09-2016, 09:26 AM
I was getting a strange delay comp value. 544 samples at 48 kHz, 832 samples at 192 kHz.
Old 04-09-2018, 09:06 AM
sdmaas sdmaas is offline
Any light on this subject? Figure out the problem? I am getting 4146 samples of delay on ANY aux track now for some stupid reason. I am freaking out
Maximum Automatic Delay Compensation HDX corp Pro Tools 10 4 01-20-2012 04:19 AM
Automatic Delay Compensation? Dax Xenos Pro Tools 9 15 06-06-2011 06:21 PM
Automatic Delay Compensation alfadog Pro Tools M-Powered (Win) 1 04-08-2006 07:53 PM
Automatic Delay Compensation stakeoutstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2005 01:02 PM
Automatic Delay Compensation slangification Pro Tools TDM Systems (Mac) 5 04-28-2004 11:02 AM
