Old 06-30-2005, 12:05 PM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Default Latest iTunes (4.9) doesn\'t work if you have PT?!?
I searched the DUC and found nothing on this issue.
I just updated iTunes to version 4.9 and now iTunes/Quicktime won't work. Anyone else having this problem or maybe found a work around?
I called Apple and they immediately asked if I had Pro Tools installed. So they know there is incompatability between PT and the latest iTunes/Quicktime. They suggested a few things to try but to no avail.
Are you aware of this Digi? Is a fix coming hopefully?
Thanks in advance!
mBox w/ PT 6.4
iMac G4 1ghz 768 ram
OSX 10.3.9
Old 06-30-2005, 02:05 PM
sonikbliss sonikbliss is offline
Default Re: Latest iTunes (4.9) doesn\'t work if you have PT?!?
I just installed ITunes 4.9 on my G4 1.25Ghz which is also running PT 6.4LE (002) on OS X 10.3.4 and everything is working beautifully.
Rock 'n Roll saved my soul
Old 06-30-2005, 02:12 PM
indoe's Avatar
indoe indoe is offline
It may be something to do with PT 6.4. I have a machines with 6.7 & 6.9 and there no issues with the new Itunes.
www.klearlightstudio.com
Old 06-30-2005, 07:07 PM
djjstylz djjstylz is offline
I had this problem but I think the actual problem is with the latest quicktime. There is a fix, you just have to downgrade to the older quicktime. I got the fix from a thread here so it has to be around somewhere. Also try the apple site in the downloads. They have a link to reinstall older version of quicktime which was the only fix at that point in time. Thats what I did and Itunes would work fine. The problem was Itunes wouldn't open if you have PT6.4 and the latest quicktime. Try that and see if it works.
Old 06-30-2005, 08:54 PM
djaikon djaikon is offline
I had the same problem. It was quicktime 7 that messed everything up. I upgraded to 6.9 (now I'm on 6.9.2) and ieverything's hunky dory.
Will 003 work with the latest macbook pro? roop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-11-2013 05:11 PM
Any problems with the the latest security, Quicktime or iTunes updates? WernerF Pro Tools TDM Systems (Mac) 2 04-01-2009 03:34 PM
Any problems with the latest itunes or quicktime? dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-12-2008 10:40 PM
PT 7.4.1 and Latest Quickeys Wont work - Help 25ghosts Pro Tools TDM Systems (Mac) 7 04-10-2008 12:19 PM
Latest iTunes and Digi interface incompatibility? Sadie Tango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-05-2005 10:10 AM
