Question about passive and active subs for Atmos
We are in the process of building up our main mix room to be Atmos certified. Our current sub is a little bit under powered and we are on the search for a new one. We have the MTRX with the SPQ card that is going to be doing all of the management, filtering as needed, delays, etc.
The Dolby certification spreadsheet lists a whole bunch of passive cinema subs, along with the regular powered subs for recording studios. For instance, the Genelec 7382A gets us over the hump to be qualified, but the damn thing is $10.5k! Alternatively, we could go with something like a passive Christie S118LP that is around $1000 that also gets us over the hump in terms of power. We would also need an amp of course, but it is still a huge price difference at the end of the day. I know there are things like AES inputs and that sort of thing that make it more expensive, I'm curious if there would be a huge difference from an listening/mixing perspective, with the nature of LFE, between the 2? What are you getting for that extra $7-8K (after we get an amp as well) Thanks! |
Re: Question about passive and active subs for Atmos
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
I would not do a passive sub unless it was a very big room that could fit something like a pair of JBL Cinema boxes(18" loaded) with appropriate power and system control
Thanks for the responses everybody. The sub just needs to pass muster when it comes to the Dolby certification process. There is a spreadsheet that they send you that has a bunch of prebuilt lists in it, containing dozens of pieces of gear (see attached). There are lots of active subs listed as well, but so many just don't have the power to make the spreadsheet in the green (any colored cells indicate something that is under powered and needs to be addressed). At the moment, our surrounds are also a little bit under, which we might be able to solve by bass managing them with an additional sub, which gets us another 3-4db, which will put us in the green.
Quite the process! |
Monitors; active or passive? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-20-2007 05:51 AM |
Active/passive monitors | Palli-Moon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-03-2006 07:42 PM |
Passive or Active D.I. | carnology | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-10-2005 09:02 PM |
Passive/Active | vicwind | General Discussion | 0 | 11-25-2003 08:43 PM |
Active or passive ?? | seared music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2003 11:46 AM |
