Pro Tools 12.6.1 and Axiom 61 Midi Controller Issue
Hello All, I upgraded to AVID Pro Tools 12.6.1 to other day and ever since my Axiom 61 midi controller won't work in Pro Tools, I can load a standalone virtual instrument and make it work but no luck in Pro Tools. I'M not sure if there is something specific I need to do now to make it work again inside Pro Tools, Please see my system specs below, Thank you...
Model: Dell Precision T1500 Minitower OS: Windows 10 Pro 64 Bit SP1 CPU: Intel® Core™ i7-860 (2.8GHz,8MB) Memory: 32GB (4 X 8GB) SanDisk 480GB SSD AVID: Digidesign Digi 003 Console Pro Tools 12.6.1
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Re: Pro Tools 12.6.1 and Axiom 61 Midi Controller Issue
Setup > Peripherals > Midi Controllers Tab tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X |
Yes I tried that, Didn't work, I didn't have to do that the in Pro Tools 12.5.0 it just worked? Been working since Pro Tools 8 M-Powered but since I upgraded to PT 12.6.1 the midi keyboard doesn't work anymore in Pro Tools? I changed the USB port on the computer the keyboard is plugged in and rebooted, reloaded the drivers, I'M at my wits end at this point.
Is the keyboard not working at all (as in, no notes generated), or is it just the transport controls?
tg
The Midi keyboard doesn't do anything inside Pro Tools, wont play notes no controller features, but if I load Standalone EZ Keys or Matrix 12 I can jam away on the keyboard but no midi or USB connection inside Pro Tools.
Are you seeing it when you go here?
It should be listed in the device window. If it's there, you may have to select it. I'm at work and don't have any keyboards here that I can plug in, but I'm guessing you have to select it in this window... tg
did you try going to the m audio website to up date your controller driver for os and axiom hopefully they should have what you need although they are not the biggest supporters of avid!
Yes sir I tried that, still didn't work, I think I might try my M-Audio Keystation Mini 32 and see if I can get that working next as a test.
That certainly is weird. I've only used M-Audio keyboards, and it's always been a given when plugging them in (mac or PC). They just work with PT.
on your instrument track / or your midi track .. do you see midi input levels for input ??? in the input list is the instrument selected correctly ??? does this device show up in your midi studio setup ???
standard stuff here though, nothing crazy .. just signal flow through pro tools midi ..
M-AUDIO Axiom 25 MIDI Keyboard Controller | Hannibal Lecter | Buy & Sell | 0 | 02-10-2016 10:48 AM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Axiom 25 and Midi controller | patswope | Eleven Rack | 0 | 12-17-2010 08:09 PM |
How to set up my axiom 49 midi controller with pro tools le8 on windows 7? | iva star | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-08-2010 10:26 AM |
PT 8 does not see Axiom Pro in MIDI controller window | compumar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-07-2009 06:02 PM |
