Re: Pro Tools 12.5 "Not Responding"
Hmm interesting because I have tried everything and I get the same symptoms. I have optimized my system my system so well that I am under 2 seconds start up. My Protools 10 runs lightening fast with zero issues (except can't get Waves plugins to show) and my PT 12.5.2 won't do anything....45 seconds freeze time is low compared to mine....1-3minutes. If I try to add a plug in it's a guaranteed restart everytime.
I run Windows 10. 12Gb ram, i5 3.2GHz. 1TB internal drive, 3TB 3.0USB ext. I have completely wiped it out 2x with a full 100% reformat of everything, even the back up of the backups on the HD. I reinstall only PT 12, no other things except that. nope no change. Bought a fast 3.0USB Drive which can run any other DAW I have without any issues like this but PT won't get out of it's own way. I have been on a ton of different PT forums and tried everything I can think of on why this is happening. I have a pc that should be able to run this easily and set up for audio production. I've downloaded the install file all over again, nope. Put it this way it runs Sonar Platinum 100% flawlessly with a ton of tracks and plugins open. I installed it to make sure it wasn't my pc or anything else and 100% perfect. I've wanted to switch to PT 2 years ago and if it wasn't for PT10 I wouldn't be using it at all. I think I am going to have to bite the bullet and pay Avid for support to resolve this because after 2 years of owning this, 2 different pc's a ton of wasted hours trying myself it is time to pay the man for redemption..... I have never been able to use PT12 even once but I'm stubborn and refused to ask Avid for help because I figured it was something I was doing wrong but at this point I give up.....U N C L E.... |
well just so you know, 12gb ram is under the actual system requirements of pro tools:
http://avid.force.com/pkb/articles/e...m-Requirements before you spend money on a support call, just know Avid will tell you your setup is not meeting the minimum requirements. Just wanted to point that out.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
That page was updated in the last month or so. When 12.5 was released several years back, these were the system requirements:
Minimum System Requirements – PC Windows 7 64-bit, Intel Core i5 processor, 8GB RAM, 15GB HDD space, iLok 2 Mac OSX 10.8.5, Intel Core i5 processor, 8GB RAM, 15GB HDD space, iLok 2 |
Thanks though. |
"Application Not Responding" When I Separate Clips in Pro Tools 10 | Red Door Recordings | Pro Tools 10 | 3 | 08-11-2015 02:43 PM |
Pro Tools 10.3.10 "Not Responding" | AnthonyPucino | Pro Tools 10 | 5 | 05-21-2015 05:11 AM |
Pro Tools "Not Responding" While Bouncing Audio to Disk | OTPBAND | Pro Tools Express on Windows | 3 | 12-20-2014 03:33 AM |
"Pro Tools not responding" error and a very "laggy" session! Help! | drumbumd | Pro Tools M-Powered (Win) | 0 | 02-10-2012 05:37 PM |
" Not responding" msg in win7 while starting pro tools v9 | q8test | Windows | 2 | 07-31-2011 10:54 AM |
