Old 10-25-2020, 06:23 AM
marre marre is offline
Default Cant select anything but L in a multi-mono plug in
Today with the help of two forum members (thank you SPOONS and ORIGINALSCOTTYG) I finally solved the problem of selecting any channel EXCEPT L in a multi-mono plug in. This has prevented me from using any mono multi plug ins on a DX stem, e.g. a DeEsser since I couldn't show the C channel.
It turns out to be related to Eucon - quitting Eucon makes the problem go away!
And another solution is to Option+clic the channel selector and 6 separate windows pop up showing the settings of the different channels. A bit clumsy.
The problem only exists on my HDX system. On my MacBookPro it works as expected.
Hello Eddie!
/martin
Mac Pro late 2013 3,5 GHz 6-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mac OS 64 GB 1866 MHz DDR3
BlackMagic UltraStudio Express
Pro Tools Ultimate HDX 2020.9
S3 - Dock - PT Control
Old 10-25-2020, 01:44 PM
reichman's Avatar
reichman reichman is offline
Default Re: Cant select anything but L in a multi-mono plug in
Yes, this got worse, then it got better, and sometimes it's still a problem...
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 10-28-2020, 10:37 AM
filmixer filmixer is offline
Yes. Super PITA. There's a new thread on the S6 about this. They need to fix it.
Mark Ettel C.A.S.
Old 10-28-2020, 10:48 AM
Yup, totally clumsy. It was just to get you up and running with multi-mono plugins ASAP. One option might be to save a Window Configuration with the channel you want showing and the other 5 windows closed...but I'm not totally sure that would work. EDIT: based on this response in the original thread, it looks like Window Configs will work: http://duc.avid.com/showpost.php?p=2581186&postcount=7
Yes. This needs to be fixed as soon as possible.
Scott Gatteño
Multi Mono Plug-in repost hughwes Pro Tools TDM Systems (Win) 0 05-23-2008 11:07 AM
Multichannel plug-in vs Multi-mono plug-in? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2007 09:45 AM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2005 01:01 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2005 11:59 AM
Would Someone Please Explain Multi Mono Plug Ins? tomhartman Pro Tools TDM Systems (Mac) 2 07-09-2002 01:07 PM
