Old 07-16-2018, 09:47 PM
LukeHoward LukeHoward is offline
Default Re: LG ultrawide display & CPU problems?
In the end I moved my 4K display to my laptop and went back to a good ol' 20" Cinema Display. Which is fine CPU-wise, but it's hard to go back to non-retina, particularly when working zoomed out on large scores.
https://lukehoward.com/
Old 10-19-2018, 12:18 PM
685 685 is offline
I will look into this as I get -9093 errors(cpu spikes) when I open/edit settings on a Waves plugin. Runs great with the plugin inserted and the plugin window closed. I always have to move the buffer up. I was also looking at getting a new graphics card in hopes of fixing the problem. First, I will try to swap out my mini DP to HDMI cable for a mini DP to DP.
2010 5,1 2.93ghz 12core, HD5770, 24gb
OS 10.13.6, PT Ultimate 2018.10
*Same thing was happening with 10.13.3 and PT 2018.4
Old 01-17-2020, 04:57 PM
It does seem better since upgrading to Mojave and recent version of Pro Tools. But the UI is still sluggish compared to running at non-Retina resolutions and the GPU usage is at 100% once a Pro Tools session is open.
Edit: the high GPU usage seems to be only an issue when the Edit window is displayed, and then seems to scale with track height. I wonder if it is to do with the metering.
Just bough an Ultrawide Monitor - WOW noah330 Pro Tools 12 12 11-23-2018 12:18 PM
10.3.5 on a Mac; display and PB problems Ty Ford Pro Tools 10 7 06-12-2013 09:51 AM
Display problems Scintillaterich Pro Tools M-Powered (Win) 3 05-22-2007 08:24 AM
!Firewire to Ultrawide SCSI conversion! Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 07-31-2001 12:20 AM
Scsi 160?lvd? Ultrawide? SCSI3 ?-Ide ata100 Morningstar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-06-2001 08:13 AM
