Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 02-19-2015, 02:56 PM
Greg0man's Avatar
Greg0man Greg0man is offline
Default Re: Audio formats pro tools.
WAV uncompressed PCM:
24-bit Bit depth
48 kHz sampling rate
2034kbps bitrate
Bounce to drive at same quality
DAW Protools 10
VS, MP3 and bounce as Mp3 at highest quality encoding at 320Kbps
Intended use is for Internet.
Bottom line i think is that the source audio file should be recorded at the highest quality using highest audio formats possible, because , Internet sites ,eg; facebook Youtube will compress to suit them
selves .
Old 02-19-2015, 03:16 PM
Yes absolutely if you can pick up the same source material then go for that uncompressed PCM source material.... if that was the question. There is no down side to you.
Check online about things like getting best bitrate playback on YouTube, lots of info out there, some contradictory/possibly out of date. On paper at least you might be border line if you should give youtube something better than that MP3 for best encoding with HD video, but there is lots of confusion out there about what exactly YouTube does. Might be good stuff for some experiments or reading what tests others have done recently.
Finding Help on Video Formats which Allow Original, Uncompressed Audio File Masters? taylor4814 Post - Surround - Video 1 07-06-2014 10:30 AM
Audio formats for download petmar General Discussion 13 10-06-2009 05:01 PM
Import audio to Avid: what formats work? Zumwalt Post - Surround - Video 2 08-16-2004 08:50 AM
Audio File Formats which to choose? Rock_Artist General Discussion 1 08-22-2002 02:37 PM
AudioVision audio file formats? Willie Myers Post - Surround - Video 2 10-09-2000 11:21 AM
