Old 03-11-2009, 12:45 PM
Ryan H Ryan H is offline
Default Installing a Plug-In?
I have installed a plug-in manually, and I can see the plug-in under the Options/Plug-Ins tab, however when I go to the Plug-Ins tab to begin using it, I cannot view it anywhere in order to install it. Have I missed a step, or installed the plug-in into the wrong folder? Also, how do I deliniate the plug-in folder in which it installs, (i.e. Dynamics, EQ, etc.)?
Old 03-11-2009, 10:08 PM
Geb Geb is offline
Default Re: Installing a Plug-In?
Hi Ryan,
If the plug-in is visible in the Options/Plug-Ins page, that means that the plug-in files have been placed at the right location. You then need to wait for the rack status to stop blinking and go to a green 'OK' (bottom right corner), which I assume you did. Before then, the new plug-ins may not all have been recognized yet. Once you are past that point, the new plug-ins should be available in the Plug-Ins tab, just like the others. If that's not the case, one of several things might be happening:
  • the plug-in might not contain a TDM HD Accel effect that works on a 321 DSP (that's the only DSP flavor available in a VENUE system). Also, RTAS, AudioSuite and HTDM plug-ins are not supported. I read in the digi support pages that some HTDM plug-ins are sometimes simply listed as TDM. Check with your plug-in vendor if the plug-in works on 321 DSPs.
  • the plug-in authorization might not work. If the Pace copy protection isn't working for some reason, that's what you might see.
  • the plug-in *might* have been designed to not load on VENUE to force you to buy a special version for VENUE. Again, check with your plug-in vendor. By default, a TDM plug-in that works on 321 DSPs will work on VENUE unmodified, but a vendor may decide on an other policy.
  • Did I forget a possible reason?...
Since you haven't specified which plug-in (and which version) you are trying to use on VENUE, it is impossible to tell if the effect you are trying to use should work on VENUE...
Each effect declares which category(ies) it should be listed in.
I hope this helps!
-g
Old 03-12-2009, 07:07 AM
The plug-in I am attempting to load is SPL Transient Designer. I know others are using it. I have downloaded the 14-day trial, and have downloaded the iLok license as well.
Un-installing plug ins Psychonaut4 macOS 1 04-15-2012 09:31 PM
Installing plug ins Cmill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-13-2007 08:22 PM
Installing plug ins tonedef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-02-2006 08:07 PM
installing plug-ins dominium1 Tips & Tricks 2 08-31-2006 12:00 PM
Installing Plug-Ins Steel City 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-01-2005 04:58 PM
