Old 10-09-2019, 09:08 AM
itsmemagic itsmemagic is offline
Default Changing Display Module Views From the Surface
I'm unable to change Display Module view for an individual strip. (S6 19.7)
As per S6_Guide_v19.5.pdf:
1.On a Fader Module press and hold Attention on the desired strip.
The strip Select switch lights and the OLED displays Meter below the Select switch.
2.Press the Select switch.
3.Pressing Display 1 and Display 2 zooms waveforms in/out instead of toggling other views.
Old 10-09-2019, 09:31 AM
creativecontrol's Avatar
Default Re: Changing Display Module Views From the Surface
I believe there were some typos in the User Guide that we found recently. Here's what should work for individual and all strips:
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-09-2019, 10:07 AM
Thanks, but I think there's a bug with this functionality.
It works initially but as soon as you either Attention any channel or engage "Layout Mode" it breaks and Attention+Select doesn't do anything anymore. Create a new session and test for yourself.
Old 10-09-2019, 11:54 AM
I'm not seeing any breakages with Attention + Sel on Current+ versions of S6. Let me revert to S6 19.7 and see if I can make it fail.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-10-2019, 05:41 PM
Greetings,
Is it possible that you have an On Attention Zone for Knobs active in the same bucket that you are attempting to tweak your individual Display Module views on? Please try suspending the Zone then attempt a global or individual display view change. Let me know. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-18-2019, 10:36 AM
Correct Jeff. Suspending "Attention Expand Knob Zone" lets me change global/individual display view.
Old 10-19-2019, 03:49 AM
Thanks for the confirmation.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Fader Module meter led display with 5.1 tracks o-matic Avid S4/S6 13 08-27-2021 08:17 AM
Display Module Request - Maintain strip view/ignore expanded knob information jmattchan Avid S4/S6 4 09-11-2018 07:32 PM
Feature request for changing Edit and Mix Window Views Pablo_D_R Pro Tools 11 3 04-15-2017 09:01 AM
Assertion Bug when changing track views. benwalker Windows 0 09-15-2014 04:35 AM
changing sends assignment views jackp Pro Tools TDM Systems (Mac) 0 10-21-2012 09:13 PM
