  #31
Old 01-19-2014, 08:33 AM
praskal praskal is offline
Default Re: PT11 crashes and is horribly slow
1. That beta focusrite driver worked. Now I can hear the click track, I can record. Excellent. thanks.
2. But when I play back, I cannot figure out how to get the track sound into my headphones (which are plugged into the 18i8). I hear the click track upon playback, but not the recorded track.
3. The external HD is My Passprt Slim 1TB.
Patrick
Patrick Rask
  #32
Old 01-19-2014, 09:46 AM
Default PT11 crashes and is horribly slow
Most WDC external drives are just awful for Pro Tools. They usually contain slow "green" drives that spin at speeds like 4,800 rpm and worse do ugly power management tricks that are toxic to Pro Tools. WDC go out of their way to obscure what actual drive and drive are packaged inside these enclosures. Any time a vendor does that, wants to hide information and assume its customers are idiots... then run, don't walk away.
A Pro Tools audio/session drive it really should be a 7,200 rpm or faster HDD or a good SSD like a Samsung 840 Pro or Evo SATA drives or a Lacie USB3 SSD drive. If you want a HDD not an SSD then companies like Glyph, G-Tech, OWC make professional/media oriented external HDD that are popular for Pro Tools use. They will notably either spec the drive RPM and/or say the drive is suitable for use with Pro Tools.
Running to a slow drive might work fine for a simple session with few tracks but is likely going to get unreliable as you increase tracks, sample rate or add plugins and VIs.
If your laptop has USB 3 be sure to get a USB 3 external drive with a proper spec HDD or SSD inside, but just getting a USB 3 drive does not mean that the vendor has put a decent drive in it.
  #33
Old 01-19-2014, 10:03 AM
Now we are back to guessing about your setup. Can't hear in headphones and can hear in monitors? Or can't hear in headphones and can't hear in monitors? Or can't hear in headphones and don't have any monitors connected? Headphones plugged into which headphone socket (they are different).
Track level turned up? Master volume turned up?
But most importantly... you need to read the 18i8 documentation to understand what outputs in the Focusrite the different headphones sockets are connected to, understand the MixControl related settings and set the Pro Tools track or mix to the correct outputs to get to the headphone socket your headphones are plugged into. Now things are working at all this is a time to do some documentation reading.
  #34
Old 01-19-2014, 12:21 PM
OMG. Now back to square one. When I open PT11 I get an error message staing that "The selcted ASIO audio device could not be initialized. Please choose another audio device". Then "quit" or "OK". This is ridiculous.
Patrick Rask
  #35
Old 01-19-2014, 12:23 PM
Relax, you likely have the wrong playback engine selected. Hold down 'N' while starting Pro Tools and keep it held down and then select the correct Playback Engine when the playback engine dialog box appears.
  #36
Old 01-19-2014, 03:44 PM
Shan's Avatar
Shan Shan is offline
Good news to hear.
Do the above that Darryl suggests.
I also very highly recommend reading this to get you started:
Introduction to Pro Tools
It's a brief 36 pages with lots of illustrations.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #37
Old 01-30-2014, 04:33 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hi Everyone,
Thank you for the thread.
I did find your case praskal and will reply to you again directly just after this.
I am glad everyone here is now finding the beta 2.5b4 driver. http://beta.focusrite.com/releases/f..._usb2_drivers/
This is an odd situation where we are finding that some users of Pro Tools only have better performance on this driver than the full release driver.
Originally it was a follow up to the 2.5b3 driver that eventually became the full release 2.5.1 driver. However once 2.5b4 went live as 2.5 we had some issues with it that had never presented in beta testing and we pulled it back, releasing the prior 2.5b3 as 2.5.1. Thus sometimes if you install 2.5b4 your computer will think it is an older driver than 2.5.1 and sometimes it will not. So make sure to uninstall 2.5.1 if you are trying to use 2.5b4 from your Add/Remove Programs.
I am not a driver programer so I really do not know the exact reason, but in the last month or so I have been trying this alternate out on my Pro Tools customers and have noticed a pattern of it solving odd playback issues such as Playhead not moving at all or "unable to initialize Focusrite USB 2.0 Audio Driver."
I have brought this to the attention of the Development Team for further investigation.
We also think the "unable to initialize" message is actually a rewording of the infamous "ASIO Device Properties have changed" in Pro Tools 11. It seems to appear at all the same times, have the same random infinite loop issues and I haven't seen any "ASIO Device Properties have changed" messages in 11. Possibly a rewrite?
Anyway thank you all for your efforts and directing me to this thread.
Please do feel welcome to contact us directly if your support issues include a Focusrite Interface of any kind. We are happy to help get you set up on Pro Tools.
Kat
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Boss ME-25 crashes PT11 oNeKOG Pro Tools 11 0 03-18-2014 11:19 PM
PT11.0.2 extremely slow load, response, hangs at XPAND!2 Jenk2k Windows 2 01-12-2014 09:20 PM
PT11.0.3 crashes after search in Workspace Hanswurstlsepp Pro Tools 11 3 11-26-2013 10:36 AM
20+ Hard crashes PT11 ReachMusicProductions Pro Tools 11 17 11-18-2013 05:10 PM
What went so horribly wrong?? dubaifox Post - Surround - Video 10 06-15-2009 11:34 AM
