Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 06-15-2012, 10:21 PM
jblob jblob is offline
Unhappy I beg of you...........
I suck at this forum business, this has probably been written 1 million times but
$5000 and 3 years later i am at a head
Simple???
NO sound through headphones
MBOX3 PT express
RODE K2 through power supply into mbox
signal showing in pt but no sound
input analog 1 mono
output re-amp L/R stereo s/pdif left right
phontom off
volume up
gain up
no s/c in pc just onboard sound with motherboard which is working
FECK!!!
Now i cant even get into pro tools! it says my mbox isnt in??
remover drivers and installed up to date ones still not working...
please help...
Old 06-17-2012, 08:18 AM
Default Re: I beg of you...........
Thanks to noone from this forum i figured out my problem
wiped everything off the pc
protools mbox drivers, software etc....Start fresh!
after downloading everything again i disabled the network adapter, installed evrthing, launched the software, signal good, output thru h.phones check!
everything works!
its not easy to figure all of this out on your own, but when you do, it feels good!!!
hope this helps someone!!!!!!!!
System Details
Win 7 64bit
ASUS Z68-V PRO motherboard
750w Power supply
nvidia GTX graphics
S.Card - onboard motherboard sound card
8gb ram
Intel i5 2500k processor
Mbox3 + protools express
Rode K2 + power supply
SOLO610 preamp
Old 06-17-2012, 07:56 PM
Shan's Avatar
Shan Shan is offline
If you havent already, dont forget to do the W7 Optimizations for Pro Tools.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 06-17-2012, 11:29 PM
Dism Dism is offline
everything works!
The problem is you're using PT Express/SE. None of the experienced users here use that version.
It seems to me you're at odds with your costs... I mean, you spent $5000 on gear just to use the free, highly stripped down version of Pro Tools?
If you want a good free editor, use Audacity. Don't bother with Pro Tools unless you pay for it. I don't mean it as any offense, it's just that no one in the pro world uses it, and therefore can't help much with troubleshooting. Avid seems to largely ignore this user base as well.
You could probably find a copy of PT8 on eBay for $100.
Glad you got your troubles sorted, but you won't find much help around here unless you're using LE or better.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-19-2012, 02:41 AM
Cool Re: I beg of you...........
thanks for the tip!
yeh i was referring not only to the mbox but a whole bunch of gear i bought to get setup!
cheersh
System Details
Win 7 64bit
750w Power supply
nvidia GTX graphics
8gb ram
SOLO610 preamp
Old 07-17-2012, 10:53 AM
YYR123's Avatar
YYR123 YYR123 is offline
jblob.....i bet it was the i/o setup......Maybe next time....
Daniel
