Old 05-03-2010, 07:51 PM
gsilbers gsilbers is offline
Default USB to Ethernet Adapter with Euphonix mcmix
i have a usb to ethernet adapter and dont know if its not working because of it or because the regular setup.
i had the mc mix connected to regular ethernet port and it work fine. now that i switched to the adapter i can still see the 8 fader bank lines on the tracks but
the faders are not moving. even with the same sessions i had used it successfully before.
do i have to re install anything or change setups or something now that i changed to the adapter. ?
im on a macpro 2009 under snow leopard. and i need the other ethernet ports for other things.
Old 05-04-2010, 06:12 AM
JeromeOD JeromeOD is offline
Default Re: USB to Ethernet Adapter with Euphonix mcmix
Can't you use an ethernet hub or switch? The mcmix/controls are tcp/ip devices so should work through normal Ethernet routing equipment. A USB adaptor doesn't sound like a great idea.
Jerome O'Donohoe - TV and Film audio post in London, UK and thereabouts. www.fade-up.com
Old 05-04-2010, 08:22 AM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Lightbulb Re: USB to Ethernet Adapter with Euphonix mcmix
The USB device will work if you set it up correctly.
Since this is a "directly connected" configuration we recommend setting up a manual network including a Static IP address on the surface.
Check the Euphonix FAQ: http://www.euphonix.com/artist/support/faq.php
"How do I connect directly to a Mac?"
Once the USB-Ethernet port is alive and configured in System Preferences / Network you need to choose this is the default EuCon network device.
Go to: system preferences / Euphonix and select it using the device drop-down menu. YOu will need to log out and back in for this to take affect (or reboot).
Old 05-04-2010, 11:57 AM
thx
ill check it out. the usb ethernet didnt come "alive" or showed up on the mac until very late last night so ill troubleshoot some more later.
btw. yes i could add network hub but there is a reason i dont but wont get into it.
USB-Ethernet adapter andreasaidu Artist Series 6 02-18-2011 10:16 AM
AVID bought Euphonix. McMix/Control now or later? Tao Jones Pro Tools M-Powered (Mac) 1 04-11-2010 04:55 PM
No Ethernet port left for the Euphonix mix :( gsilbers Pro Tools TDM Systems (Mac) 7 03-18-2010 08:14 PM
Control 24 w/ USB->Ethernet adapter? The Chinese Pro Tools TDM Systems (Mac) 3 04-23-2009 12:55 PM
USB to ethernet adapter Craig F ICON & C|24 10 12-18-2007 12:11 PM
