Old 05-31-2008, 01:57 PM
Arlanda Arlanda is offline
Default Pro tools LE and M-powered installed at the same time
Hello!
I use Pro tools M-powered, but recently borrowed a digi 002 for a project where I needed more then my usual 2 inputs. The problem was that I couldn't install Pro tools LE and therefore couldn't do the project in pro tools.
When I opened the installation-file there was a popup, I don't remeber exact what it said but I think it was about that I have M-powered 7.4 and was trying to install an erlier version of LE.
Is it possible to have both installed at the same time? If so, what's needed to install?
//Stefan
Old 05-31-2008, 02:29 PM
therecordinghouse therecordinghouse is offline
Default Re: Pro tools LE and M-powered installed at the same time
you can install mp and le on the same machine from version 7 up. however, they must be the EXACT same versions. ie, 7.3.1 mp and 7.3.1 le. this is not the case with the most recent release for leopard though. which is 7.4.2pr.
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
Old 06-03-2008, 12:13 AM
Does that mean that if I upgrade my M-powered to 7.4.2 I can install an older version of LE?
Old 06-03-2008, 09:47 AM
barstool719 barstool719 is offline
no, it means they have to be the same version.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 06-04-2008, 08:10 AM
So what does that part mean?
Old 06-04-2008, 06:29 PM
that you can install LE 7.4.2pr (which is a pre-release) beside MP 7.4.1. (or just 7.4. same difference.)
id bet that when the final release of LE 7.4.2 comes along, it would also need MP 7.4.2.
to re-iterate:
to install protools LE and MPowered on the same machine, they must be the same major/minor/revision number. (eg LE 7.4.1 and MP 7.4.1)
Old 06-05-2008, 08:08 AM
Ok, think I got it now
Thanks a lot!
Installed Pro-Tools M-Powered, now I get this error when I try to run it... joecalv Pro Tools M-Powered (Win) 1 08-20-2010 08:48 AM
Does Pro Tools m-powered esseintial have elastic time? KyleACounts Pro Tools SE and Essential (Win) 1 02-18-2010 12:30 PM
possible to have M-powered and HD installed on same system? Judson Pro Tools TDM Systems (Mac) 1 08-27-2009 08:39 AM
How can I keep LE 6.4 installed & run M-Powered 7? DUCHUNTER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-20-2006 07:41 PM
May I have both LE and M-Powered installed ?!?! Mamede Pro Tools M-Powered (Mac) 9 10-07-2005 03:51 PM
