Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 05-29-2020, 04:43 PM
GroovnD313 GroovnD313 is offline
Default PT 2020 Whats Up With The Crazy CPU Spikes?
Sessions that ran around 60% in 2019.6 cause immediate cpu spikes before playback can even start. I've tried 2020.3 and also .5 (2020.5 btw crashed every time I closed a session, but thats another issue). Anyone else experiencing this? I can't even use it and had to go back to 2019.6. Not a huge deal but I would like to use it since I'm paying for it :)
I run a super clean system, plugins up to date. Mojave 10.14.6 All the usual things...It's a older iMac and I push it pretty hard but it gets the job done.
Old 05-29-2020, 06:42 PM
Default Re: PT 2020 Whats Up With The Crazy CPU Spikes?
I'm not a Mac expert, but I suspect its that you are trying to use the newest PT on a slightly older OSX. You might need to either upgrade OSX or downgrade PT(downgrading PT is probably best on an older Mac)
Old 05-29-2020, 09:27 PM
Don’t think so. Like I said I’m on Mojave.
Old 05-30-2020, 01:40 AM
clausiii's Avatar
clausiii clausiii is offline
do you use VIs? and if yes which ones?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.5
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-30-2020, 04:01 AM
Carl Lie Carl Lie is offline
I'm sure you've checked this but each new install resets your buffer settings.
I'e been caught off guard by that.
C
PT 2019.12 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 05-30-2020, 09:01 AM
C
Really... that totally could have been it. I'm on 1024 since I'm a mixer and it never ever changes (by me at least). I might have to re-install it just to check that thanks!
Old 05-30-2020, 09:04 AM
No VI's. They are just mix sessions. One session is only Waves V11 plugins so there are no 3rd party esoteric things causing it.
Old 05-30-2020, 09:31 AM
C
What's strange if that is the case, is that after re-installing 2019.6 my buffer is still at 1024. I'll try 2020.3 again today and double check this.
Old 05-30-2020, 10:45 AM
It probably depends on your preferences. Maybe it doesn't anymore.
Not sure. Only thing I could think of.
C
Old 05-30-2020, 12:30 PM
So after re-installing 2020.3 again and double checking the buffer I can report it's not that. And it did stay at 1024 after installing. De-activating every plugin in the session and re-activating them one by one does not show any strange jumps and just leads me to believe that it simply just does not run as efficient as 2019.6
Export video is crazy slow on 2020/Mojave melodydetective Pro Tools 2020 1 05-21-2020 11:13 AM
Pro tools 2020.3 Crazy Cpu and Ram % JeroRomero Pro Tools 2020 34 05-15-2020 08:03 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
CPU spikes like crazy tobbelito Pro Tools 2018 3 10-17-2018 03:42 AM
