Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 05-20-2020, 01:18 AM
Rockman413 Rockman413 is offline
Default Can we use the video import/export now on Mac Pro/Catalina?
Hi there,
I got a new mac pro which ships with Catalina, but it seems pro tools HD does not support import video or export video with the sounds I make because of Catalina. Is this still the case? Is there any workaround?
It would be very hard since I work with pictures and there's no way to import video.
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 05-21-2020, 07:19 AM
Default Re: Can we use the video import/export now on Mac Pro/Catalina?
I'm sure there're other users who bought new mac pro and work with videos?
Old 05-21-2020, 07:40 AM
JFreak's Avatar
JFreak JFreak is offline
List of Catalina compatible codecs here
Janne
Old 05-21-2020, 08:53 AM
Thanks!
1. Where can I see the codec I've already installed?
2. Where can I download the Codecs mentioned in this article? I found codecs LE/PE in my user account but that's all I can find.
Old 05-22-2020, 05:46 AM
does anyone know about this?
Old 05-22-2020, 03:38 PM
EarHole EarHole is offline
Just diving into this myself so bear with me.
Catalina ended support of QT because it's 32 bit. There are some apps that have limited access to it.
You can download Video Slave which will still use QT files and it's an external video timeline you can sync with PT.
You can also download ffworks with ffMPEG and convert your QTs to MFX files that can be imported into ProTools. Then you export your mix and use FFworks to attach that mix to the existing vido.
It's all a huge mess honestly and I'm hoping Avid figures something out quickly.
Old 05-29-2020, 04:31 PM
epmi epmi is offline
It's unfortunate, since it is the most important feature missing from PT on Catalina for music editors. In my case, when working on a project, I often output preview QTs several times a day. Having to use another program -- such as the recommended app "Video Slave' --to do this is extremely inefficient. I'm also surprised that there has been no timeline provided for when they will be reinstating this basic functionality.
Post with Video on Catalina EarHole Post - Surround - Video 6 05-11-2020 05:49 AM
2020.3 Catalina video support andystar Pro Tools 2020 4 04-01-2020 11:43 AM
Import Video - Audio Import Option Disabled sarcanon Pro Tools 12 2 06-14-2016 05:12 PM
Mxf import / export JJG Post - Surround - Video 0 08-24-2005 12:25 AM
OMF import/export kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-06-2003 09:23 AM
