Old 05-15-2020, 09:10 PM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Default HD10 mountain lion Mac Pro 5,1 not working
HD8 was running fine
Installed HD10
Got this error
So I upgraded to Mountain Lion 10.8.5
Still got the same issue
Any help appreciated.
https://www.glasshousestudios.com.au
Mac Pro 5,1 (Early 2009)
2 x 3.33 GHz 6-Core Intel Xeon
96 GB 1066 MHz DDR3
macOS Mojave 10.14.6,
Radeon RX 580 8GB
Antelope Audio Orion 32 HD
Pro Tools Ultimate 2018.12
HDX card
Old 05-15-2020, 11:28 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: HD10 mountain lion Mac Pro 5,1 not working
Can’t see the pics, I had nothing but love for 10.8.5, that was a great release.
I ran PT10.7 on it for several years without issue
Daniel
Old 05-16-2020, 01:55 AM
crizdee's Avatar
crizdee crizdee is offline
Installed HD10
Got this error
Did you uninstall PT 8 before attempting to install PT10.
You should use the uninstaller that comes with the version you want to uninstall so you should run the uninstaller for PT8 HD.
Complete uninstall. Repair disk permissions. Reboot. Reinstall.
What OS were you running with PT 8?
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-12-2020, 07:42 PM
s.d. finley s.d. finley is offline
that combo should work like a dream. I would wipe the HD clean and do fresh installs all around. Sure its a PITA but it is going to work wonderfully afterwards
sdf
www.sugarhillstudios713.com
Old 07-08-2020, 06:22 AM
groovebrother groovebrother is offline
agreed, clean installs are the best way ever.
It can also work like a charm on Mavericks - i Just move to it last month after years using 10.6.8 & 10.8.5
no issues at all
but always after clean install
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 32Go Ram / PE6R4-i - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate - 192 i/o Digidesign - MTPAV - OSX : 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13
Mapping Keyboard Shortcuts in Mountain Lion Not Working cuttothebeat Pro Tools 11 0 12-02-2013 02:28 AM
MBox mountain lion drivers not working DelChivo macOS 16 11-03-2013 04:48 PM
10.3.6 not working in mountain lion 8.4 mortenbrekke Pro Tools 10 5 06-26-2013 12:00 PM
Lexicon PCM Native Reverb and Mountain Lion-Working? Will Russell Pro Tools TDM Systems (Mac) 7 09-11-2012 08:25 AM
Pro Tools 10.2 HD Native on Mountain Lion, Successfully working! saproduction Pro Tools TDM Systems (Mac) 11 08-24-2012 02:32 PM
