Old 04-20-2020, 10:14 AM
francois francois is offline
Default D-command flicking display
Hi it's time for opening the main unit board again
I have a few power supplies back up and if someone could direct me to which power supply go to with the flicking display it would help me
Thanks
Francois
PT 2020 ultimate -HDX1- OSX 10.15- MacPro 7.1
- D-command 24-Trinnov Dmon
Old 04-21-2020, 06:27 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: D-command flicking display
Thanks
Francois
As you look from above.
from left to righ, Faders - LED - Logic..
Faders board SNP-Z107
Led Board SNP-Z10B
Logic board SNP-9544
likely to be the LED board but can never be sure.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-21-2020, 09:00 PM
Thanks Chris
D-command display only active tracks?? tioshi ICON & C|24 1 09-26-2016 02:57 PM
Command¢8 display issue pvollenweider ProControl, Control|24, Command|8 4 10-23-2015 07:58 AM
D-Command individual track display?? dunebuggy macOS 3 02-27-2013 05:02 PM
Command 8 display d.B.Music ProControl, Control|24, Command|8 0 02-13-2009 05:41 AM
Display problems on D command ctv mtl ICON & C|24 4 06-05-2008 07:53 AM
