Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 04-16-2020, 10:55 PM
toodamnhipPT toodamnhipPT is offline
Default Is it OK to disable delay Comp on Master Bus?
After finding out that Recording midi and audio play back off time by 2000 samples with Sonarworks on the Matter bus, I tried "disable plug in delay" on just the Master bus and now, I can record MIDI and Audio with Sonarworks on the Master bus without any timing issues.
Is it ok to "disable plug in delay" on only the Master bus? Will it affect anything else in my session? So far, I see no harm in it, but I am new to Pro Tools since 2000 when I last used it. Thanks
Old 04-17-2020, 04:54 AM
musicman691 musicman691 is online now
Default Re: Is it OK to disable delay Comp on Master Bus?
I don't think you can disable delay comp on a single buss or track; it's an all or nothing proposition.
toodamnhip - I seem to remember a fellow going by that name over in the Motunation forum for Digital Performer users. Same person by any chance?
Jack
QAPLA!
Old 04-17-2020, 05:28 AM
crizdee's Avatar
crizdee crizdee is offline
Yeah you can disable delay comp on the master bus.
Might need it if you're syncing with video and bouncing etc
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2020, 05:49 AM
Originally Posted by crizdee View Post
Chris
You can do it on a single bus? How do you do that? I've never got into disabling delay comp.
Jack
QAPLA!
Old 04-17-2020, 06:05 AM
ChuckS ChuckS is offline
Right-click on the Delay amount at the bottom of the channel strip.
PT 2020.5 DP 10.11 VEP 7.x MOTU M4 HP Envy 8G i7 Quad Laptop Win10 (x64 20H2)
PT 2020.5 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 04-17-2020, 06:13 AM
crizdee's Avatar
Command+control+click on the top number in the delay comp window bottom of the channel.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2020, 08:11 AM
...Command+control+click on the top number in the delay comp window bottom of the channel.
Top number is the delay a channel is reporting, bottom number is total delay compensation being applied to the channel - usually you'll want to disable (cmd-ctl-click) the *bottom* number, though in some (but not most) cases the two will be the same.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 04-17-2020, 11:09 PM
Indeed, Ive moved on over to the Dark Side. lol...
Old 04-17-2020, 11:13 PM
Chris
Thanks for your help Chris! In a later post you give that key command. That is my life now, learning PT key commands, having been a wiz at it 20 yrs ago and being in DP land ever since. Now Im back, missing DPs customizations and features, but truly loving the solidness and efficiency of the Dark Lord.."Pro Tools the ever present, ubiquitous one". But I am so sad that AAF or OMF don't seem to bring over plugs ins. Sigh sloppy playing to learn how to edit..
Old 04-18-2020, 04:09 AM
Welcome to the fold.
Jack
QAPLA!
Delay Comp problems again, Delay comp is RED but way below limits. soundeq Pro Tools TDM Systems (Mac) 13 11-29-2011 12:01 PM
Can you disable Delay Compensation on Master? AINSLIE Pro Tools TDM Systems (Mac) 7 02-15-2008 09:56 AM
PSP Master comp, nearest plugin comp to Manley Vari MU? crizdee Pro Tools TDM Systems (Mac) 1 05-22-2007 05:21 PM
WOW, NO LIMIT on delay comp w/master and auxes!!!! McMasters Pro Tools TDM Systems (Mac) 0 05-01-2006 10:11 AM
Delay Comp in Master Fader cachemira Pro Tools TDM Systems (Mac) 3 02-17-2006 10:17 AM
