Old 04-15-2020, 02:36 PM
crizdee's Avatar
crizdee crizdee is offline
Default Ever a fix for X-MON going into mute randomly
On my second X-MON (Yeh second hand ones) in 4 months. the first starting going into mute then outputs distoring and became unusable, stripped and cleaned and it worked for a month then started going faulty again. bought another one been fine for about a month started going into mute randomly and gettting more frequent.
Might try stripping and cleaning the second one but wondered if anyone found the actual cause?
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-20-2020, 10:20 AM
francois francois is offline
Default Re: Ever a fix for X-MON going into mute randomly
YEs please .
I tried my old X-mon and it was working again after a 4 years furlough.
Francois
PT 2020 ultimate -HDX1- OSX 10.15- MacPro 7.1
- D-command 24-Trinnov Dmon
Old 04-28-2020, 08:06 PM
TheFilterLab TheFilterLab is offline
I had this problem a few years ago and in my case it was just a matter of cleaning the serial cable connectors.
Hope that helps,
Jared
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
Mbox 3 Pro on Windows 8 randomly going mute ddj1991 FireWire and USB Audio Interfaces (Win) 15 07-28-2016 04:52 AM
Speaker mute,unmute, record track mute,unmute for ADR garret Post - Surround - Video 7 09-04-2015 01:03 PM
Mute Region or Mute Automation Jeremy Mix3000 Pro Tools TDM Systems (Mac) 9 01-22-2007 07:53 PM
mute doesn't mute? kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-22-2004 08:03 PM
