Old 03-31-2020, 05:54 PM
Led Led is offline
Default Tap into onboard talkback mic without xmon - control cable pinout?
Does anyone know the actual pinout of the xmon control cable, as in what travels on what pin? I'm doing some remotes and currently using a talkback brought up an aux track sending to client, but would be handy to use the onboard mic and talkback button if I can. Don't have an xmon, but the onboard talkback mic must travel down one of the pins and ground down another or via the shell. Anyone know the actual route it takes?
thanks,
yours in isolation.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 03-31-2020, 10:47 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Tap into onboard talkback mic without xmon - control cable pinout?
I remember seeing some sort of midi pinout diagram before but I don't know if it matters how old your control surface is or not. What are you using? Hopefully a D-Command because I would love to know this info also!
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 04-01-2020, 02:49 PM
Led Led is offline
D Command ES. I've seen the midi pinout, that's for the connector on the xmon to use Eucon from memory. Might be able to wire up a connector from the control port on the D Command and try to find it with a multimeter maybe..got plenty of time on my hands...
Andy Evans
www.mud.net.au
Old 04-15-2020, 04:51 PM
Ryan Young's Avatar
Have you have any luck with this? I've been too scared to try (and I don't have a 15 pin cable to break out)
-Ryan Young
Additional Systems
Old 04-15-2020, 10:12 PM
Led Led is offline
Not this far, I need to buy a 15 pin and solder some cable up so I can sit at the front of the D Command with a multi meter. It's on the list of things to do in lockdown soon as i run out of other things. I've just been using an external mic on an aux input for now.
Andy Evans
www.mud.net.au
Old 04-15-2020, 11:12 PM
Ryan Young's Avatar
I’m doing the same but I’m now also dealing with my Omni mic pres not adjusting. That’s a story for another post.
I’m going to be buying this and see what I can do (hopefully without breaking something!)
https://www.amazon.com/breakout-Conn.../dp/B07DN9PRT2
-Ryan Young
Additional Systems
Old 04-15-2020, 11:43 PM
Led Led is offline
That's a cool looking thing, shame they don't ship to Australia. Do they have a female instead of male? If they did you could just plug the end of the control cable that normally goes into the xmon socket into it and check the screw terminals in the breakout box with a multimeter. Just have the talkback latched on and talk out loud while looking for a small voltage that fluctuates with your voice, it'd only be tiny, like in the low millivolts... I don't see how something will break if you are just measuring voltage between pins and ground...maybe if you short 2 pins together or short a pin to ground something might have an issue?
Unless you still have your spare main unit and can get to the traces in the meter bridge that the built in talkback is connected to, then just ping them with a continuity setting to the pins on the control socket?
Andy Evans
www.mud.net.au
Old 04-16-2020, 03:20 AM
crizdee's Avatar
crizdee crizdee is offline
I very much doubt it as there are no hardwire audio connections to the control surface. just data information controlling the xmon
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-16-2020, 04:45 PM
Led Led is offline
Hi Chris, I believe the onboard talkback mic that is mounted in the meter bridge travels to the xmon via an unbalanced feed in the control cable. It must, otherwise how could it get to the xmon?
Cheers
Andy Evans
www.mud.net.au
Old 04-16-2020, 05:54 PM
arche3's Avatar
arche3 arche3 is offline
The tailback pins are on the db15 control cable.
Sent from my SM-G986U using Tapatalk
Xmon, listen mic and talkback amolin Avid S6 13 06-16-2016 07:22 PM
Give me please the 1622 interface cable pinout! PUL Pro Tools TDM Systems (Mac) 1 09-17-2013 08:36 AM
XMON Eucon Software and wiring Control-Breakout Cable moacito System 5 3 05-02-2013 08:26 PM
System 5MC and XMON Talkback Mic Help Bear Jam System 5 6 11-30-2012 10:15 AM
rs232-rs422 machine control cable pinout Ghengis Pro Tools TDM Systems (Win) 1 03-30-2005 10:39 AM
