Old 02-04-2020, 07:08 AM
Branko's Avatar
Branko Branko is offline
Default Interleaved audio 7.1.2 ch order messed up on import
I'm trying to import some interleaved files mixed in 7.1.2 configuration into my session, and no matter what I do, the channel order is always wrong.
In 7.1.2, the channel order should be L,R,C,Lss,Rss,Lrs,Rrs,LFE,Lts,Rts. When I check the interleaved file using Wave Agent, it shows that the LFE is really on ch8, but it gets imported to ch5 instead.
Has anyone experienced anything similar?
Branko Neskov c.a.s.
www.loudness-films.pt
Old 02-04-2020, 11:33 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Interleaved audio 7.1.2 ch order messed up on import
I think this will help explain the default layout when importing into Pro Tools, regardless of the layout outside of Pro Tools.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 02-04-2020, 01:53 PM
Branko's Avatar
Thanks, Ryan Young for your answer. There's no mention of Atmos (7.1.2) configuration in that document. Also, all 7.1 and 5.1 files import correctly.
Old 02-05-2020, 04:02 PM
paulo m's Avatar
paulo m paulo m is offline
Hi Branko, never seen that. In a 7.1.2 SMPTE channel order, the Lfe is on the forth position and on Film mode in the 8th position. The height channels are always after that. The channel order you describe is not right, assuming is Film mode, it should be L,C,R,Lss,Rss,Lrs,Rrs,LFE,Lts,Rts. Anyway, where was the file exported from? I think is just a metadata/file extension issue and Protools is not interpreting it well on import, despite Wave Agent showing the Lfe in the right place.
Regards,
Paulo M
Old 02-05-2020, 04:10 PM
Ryan Young's Avatar
These are the layouts I've seen, where LFE is in 6th position.
File Type: jpg Screen Shot 2020-02-05 at 4.08.53 PM.jpg (30.7 KB, 0 views)
-Ryan Young
Additional Systems
Old 02-05-2020, 05:04 PM
paulo m's Avatar
Well, ya, in a 5.1 Film order, but were talking about 7.1.2 as Branko mentioned. In a 5.1.2 setup would be in 6th as well.
Regards,
Paulo M
Old 02-05-2020, 05:56 PM
Ryan Young's Avatar
It’s a screenshot of 7.1.2 layout
-Ryan Young
Additional Systems
Old 02-06-2020, 04:23 AM
Branko's Avatar
8th
Old 02-06-2020, 09:20 AM
Ryan Young's Avatar
8th
Lol gah. I’m confusing myself now. Sorry.
-Ryan Young
Additional Systems
Old 02-06-2020, 03:13 PM
paulo m's Avatar
8th
Did you find a way to import the interleaved files in the right order?
Regards,
Paulo M
HTML code is On
Track order messed up edwinstar Pro Tools 2018 3 05-24-2017 12:32 PM
Session created with interleaved audio setting are NOT interleaved Prabha Pro Tools 12 0 05-03-2017 01:13 PM
Audio Import - Interleaved / Dual Mono Broken john1192 Pro Tools 12 8 05-06-2016 03:20 PM
Interleaved Import Broken? dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 2 01-12-2013 08:27 AM
Can you change the default channel order of an interleaved.. dj_grimmace Post - Surround - Video 4 11-12-2007 08:10 AM
