Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-12-2019, 04:09 AM
Jon at Solent Jon at Solent is offline
Default Hardware Settings - Saved Where?
We need to be able to copy Pro Tools Hardware Settings to new Users on our Macs at our Uni - due to the way the build is imposed on us all new users get default Hardware Settings for the HD I/O attached to the system.
Does anyone know where on a Mac the Hardware settings are saved? We've copied a number of Preference files from a working User to a New User but without success. Once we know which file it is we can create a script to copy it to the correct location on login...
Cheers
JB
Pro Tools HD Native Thunderbolt
Avid HD I/O (8 x optical I/P, 8 x analogue I/P)
Mac Pro 6.1
Old 11-12-2019, 02:47 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Hardware Settings - Saved Where?
Saw this 2008 Post (don’t know if it’s still applicable):
http://duc.avid.com/showpost.php?p=1239406&postcount=3
Originally Posted by the dude View Post
the Preference file for the Hardware is being saved to the DigiSetup.OSX file located in:
Mac HD > Users > "User Folder" > Library > Preferences > DigiSetup.OSX file
However:
Check out Snapshot (free!) to store images of your hardware settings.
“Snap it on your phone, send it to your computer and save it in your session using the free Snapshot plug-in. You can also add notes to each instance …”
https://non-lethal-applications.com/products/snapshot
Snapshot currently supports macOS 10.9 or higher and Windows 10
https://www.pro-tools-expert.com/hom...gs-in-your-daw
Pro Tools 2020.5 and 12.5.1 HD - Studio One 4 Pro - Win10 64 Pro – Lenovo W520 ThinkPads & 433830U Docks – Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Old 11-12-2019, 11:37 PM
the.engineer the.engineer is offline
Do you mean the I/O settings?
I’m not quite sure what hardware settings is...
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 512GB Samsung SSD Audio Drive (temporary) | UAD-2 Quad PCIe
Mojave 10.14.6 | Pro Tools Ultimate 2019.12 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 11-13-2019, 12:44 AM
Hi James,
The Hardware settings are visible in the I/O Setup window and can be changed at the top, but the I/O Settings .pio file doesn't save the chosen hardware inputs and outputs format.
The Hardware Setup is also under the Setup menu and with PT Ultimate and HD hardware we can switch some inputs and outputs to be either analogue or digital. It's those settings that I want new Users on the Mac to have, rather than the default - everything analogue - which they are getting at the moment.
Many thanks
Jon
Old 11-13-2019, 12:47 AM
Hi unkJE,
I saw this as well but the Audio Engine has been redesigned since then so the DIGIsetup.OSX file doesn't appear to exist any longer. There is an Audioserver file but that doesn't appear to store the information I need.
I'll keep prodding and poking. It must be somewhere.
Cheers
Jon
Old 11-13-2019, 04:41 AM
unkJE's Avatar
In Windows, my Hardware Settings are located in My Documents.
Have you tried creating a new Hardware Setting, then “Save As”, call it Prodding and Poking, then use Finder + Show Hidden Files to find the location of Prodding and Poking, as well as all your other Hardware Settings?
(Please excuse my lack of Mac knowledge!
There are many Mac experts here who can help, if you still can't find it.)
Old 11-13-2019, 06:45 AM
Unfortunately, you can't manually 'save' a Hardware Setting. I/O settings you can and these are in Documents on a Mac. This is why I'm having trouble finding the system file that Pro Tools saves the info in. I was hoping that it was the Pro Tools Preference file, but that isn't the case.
Many thanks
Jon
Old 11-13-2019, 06:39 PM
unkJE's Avatar
These are my Mbox Pro Mixer Settings ... not what you asked for!
Realising my total ignorance of all-things Mac, I've emailed Pete Gates to ask for his help here.
Pete's a Mac Guru - http://petegates.com/
Speaking politely, by comparison, I'm rated somewhere between a Drongo and a Galoot.
Hope you get the help you need - good luck!
Old 11-14-2019, 01:34 AM
Pete Gates Pete Gates is offline
Hardly! But who doesn't like a bit of flattery.
I think, but would need to check, it's stored in
~/Library/Preferences/Avid/DSIPrefs
I'll double check when I get the chance - or just try it.
Cheers,
Pete
Old 11-15-2019, 06:59 AM
Thank you, we'll give the DSIPrefs file a try and see if that one does what we need. Then it's scripting time to get it to copy when a student logs into the computer.
All the best
Jon
buss settings don't get saved PT 12? Pedro perez macOS 0 04-01-2016 06:57 PM
Plugin settings saved? Studio820 Pro Tools 11 0 11-20-2014 04:36 AM
Amplitube settings not saved... clam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-08-2002 12:38 AM
USD/VSO settings not saved in 5.1 millerbud Pro Tools TDM Systems (Mac) 1 03-30-2001 06:14 AM
Settings not saved in PT 5.1 Robert U Pro Tools TDM Systems (Mac) 2 03-14-2001 06:52 AM
