Old 11-04-2019, 06:09 AM
Default Typing into the shift-window (option-H) broken?
I think typing a TC into the alt-H window is broken in 19.10. In the past you could just hit option-H and type away, now it seems to rotate all numbers you enter inside the frames field so you have to manually click into every section of the TC and then type the number.
Also it does seem to forward the section when there's a 00 in the entered code. Very odd but definitely broken.
F.
PTHDn 2020.5 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 11-04-2019, 09:17 AM
Pete Gates Pete Gates is offline
Default Re: Typing into the shift-window (option-H) broken?
Tried just now and working fine here (and the hitting +/- to switch between later/earlier is working too). Not terribly helpful for you but I'm not sure it's a generic bug in 19.10 though - or at least a consistent one, I'll keep an eye out as I use that quite a lot.
Pete
Old 11-04-2019, 09:57 AM
Try this:
Select something. Hit option-H. Type 01020304 (no more, no less). Result here is 01:02:00:04.
Try again: enter 04050607. result here: 00:00:00:07
01000000 result 01:00:00:00 (as it should be)
02000000 result 02:00:00:00
01595800 result 00:00:00:00
(this was in a 25fps project. result might vary in other formats)
weird!!
Old 11-04-2019, 10:13 AM
kkfaudio kkfaudio is offline
confirmed as you said...
PT Ultimate 2019.10, HighSierra
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 11-04-2019, 10:21 AM
It seems like certain numbers like 03 stop PT from pushing the next digits to the next TC field or something.
Old 11-04-2019, 11:41 AM
smurfyou smurfyou is offline
Confirmed. That is very weird and will probably be very annoying.
~Will
Old 11-04-2019, 11:53 AM
Intriguing! I only tried one number and it possibly Didn’t include 3 😂. I’ll try again when I get home but I’m now expecting it will behave in the same way you’re all seeing.
Pete
Old 11-04-2019, 01:08 PM
Yup, confirmed
Old 11-05-2019, 12:16 AM
This will likely be a PITA for people who conform manually.
Old 11-05-2019, 03:32 AM
Case opened.
HTML code is On
alt-H shift by sample seems completely broken, and therefore useless TNM Pro Tools 2018 19 01-31-2018 07:27 AM
Pro Tools 11 quit/crash when typing "Shift" Fir3bird Pro Tools 11 24 07-07-2013 07:48 PM
Is it me or is SHIFT key broken in MIDI editor?? digidesigner Windows 9 05-23-2012 02:39 PM
shift key + scroll wheel = broken dkrz Pro Tools 9 4 11-21-2010 04:37 AM
typing volume and pan value in PT8 mix window francois Pro Tools TDM Systems (Mac) 3 08-17-2009 02:27 PM
