Old 08-26-2019, 10:40 AM
Pete Gates Pete Gates is offline
Default PG PT WAV Checker
It's a little used utility but I've updated the WAV checker software - now version 1.1.0. You can now save the list of files that have errors as a text file - good idea from Marco Bernardo. Also, the MacOS version is now 64 bit.
Cheers,
Pete
Old 08-27-2019, 05:00 AM
Default Re: PG PT WAV Checker
Hi Pete,
slightly off-topic but I was wondering if you knew a trick to bulk-inject ProTools file IDs into "clean" BWAVs in a way that it drills through sub-folders and gives all the BWAVs a PT compatible ID?
Application is to "stamp" a folder with floor sound with IDs before distributing them to a bigger team so each team member is looking at the same file IDs to speed up relinking.
Currently the only method I know is to import all the BWAVS into an empty PT session so that PT gives them IDs. Downside being that PT's file import doesn't drill through sub-folders so you have to do this one by one for every floor sound folder from the shoot which can be quite a bit of donkey work on a series with 100 days of shooting.
I was wondering if you had a better idea for this!
Thanks for sharing your clever tools with us!
Frank.
PTHDn 2020.5 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 08-27-2019, 08:58 AM
BScout BScout is offline
Frank.
Do a file search by type from the top folder and then drag/drop results into ProTools. This is also possible with smart folders on macOS
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-27-2019, 10:46 AM
Hi Pete,
Frank.
Ahhhh, yes, you're the second person to ask for this. I can do it, and wouldn't charge for it as usual (I may do Some projects that aren't free at some point) but the thing that's made me resist so far is that it's destructive and if it should corrupt a weirdly formatted WAV file or something people could understandably get a bit cross with me!
Pete
Old 08-27-2019, 11:23 AM
Ah, great idea, Thanks!
Old 08-27-2019, 11:24 AM
Pete
Yeah, I guess you're right. But the idea posted above is simple and should work fine.
Thanks Pete!
HTML code is On
PG PT WAV Checker (PC Version) Pete Gates Windows 0 10-12-2016 08:27 AM
PG PT WAV Checker Pete Gates macOS 0 10-12-2016 08:25 AM
looking for good ram checker for Lion crizdee General Discussion 9 12-21-2011 11:48 PM
DPC Lat Checker HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-23-2010 12:31 AM
Useful freeware CD checker K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-31-2004 06:41 AM
