Old 05-27-2011, 04:06 AM
simonchase simonchase is offline
Default Match Duration doesn't really match duration
When relinking manually, if your file IDs have gone awry you sometimes want to relink by name only. Luckily, Protools provides this option. It even has a checkbox for "Match Duration" so you're less likely to match to a file with the same name as the file you're after but actually is a different file (eg "Audio 1_01")
Except the checkbox only half works. It won't let you link to a file that's shorter than the one you're looking for but it will happily link to a file that's longer with no warning at all that the length doesn't match and that you're therefore almost certainly linking to the wrong file.
Fix please...
PT Ultimate 2020.3 - MacOS 10.14.6 - Mac Pro (Mid 2010) - 2 x 3.46 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 RAM - SSD Startup Disk - Radeon RX 560 - AJA Kona LHi PCIe - Apogee Quartet
Old 05-31-2011, 02:47 PM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Default Re: Match Duration doesn't really match duration
This works as intended:
4 Configure criteria for relinking, if necessary, in the Linking Options dialog:
• By default, Find by Name and ID is enabled.
• To add additional matching criteria, select an option from the Linking Options dialog. (Modification Date is only applicable to Catalogs.)
If Match Duration is enabled, Pro Tools only selects files of the same length or greater.
Avid Audio Tech Support
Support FAQ
Bounced file duration Mack Truck Pro Tools 10 6 07-24-2012 12:01 PM
qestion about duration buckshot1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-21-2006 06:18 PM
duration qestion buckshot1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-21-2006 08:40 AM
file duration problem. humpback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 01-30-2006 09:48 AM
Midi Duration tnie MIDI 2 02-27-2003 07:08 AM
