Old 06-30-2008, 09:48 PM
Atardecer Atardecer is offline
Default Locking timeline position of regions when moving them
Hi there,
Just a quick question as to what the shortcut is when i want to move regions between tracks but i want to lock the start position so as to keep the same timing. Im used to doing this in cubase where you just hold down control. Had a look for the shortcut but couldnt find it!
Thanks,
James
PT HD2 7.3.1cs4, 192 I/O Dig X 2, 192 I/O, 96 I/O, Sync, ProControl w/Edit Pack, FaderPack X 3, Intel Core2 6600, 2GB, Asus P5WDG2 M/board, WinXP SP2
Old 07-01-2008, 03:22 AM
Stig Eliassen's Avatar
Default Re: Locking timeline position of regions when moving them
How about Start-Click'n'drag with the grabber tool to constrain region to vertical movement? You may need to select the region first before doing the above...my memory sucks nowadays.
Old 07-03-2008, 12:14 AM
Thanks mate,
you are spot on. Im using an edit pack on a pc so its actually the cmd key. I had tried this before but it didnt work, but then realised that i was snapping to timecode!
Jim
Old 08-04-2008, 02:35 AM
lavoll lavoll is offline
Default
lovely, i was searching for this as well. such a basic and superuseful thing :)
Old 08-13-2008, 01:36 PM
Scott Goldberg Scott Goldberg is offline
Default
You can also use apple "L" on each region or group of audio or regions. They will lock until you want to change them...right stig-meister???
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Moving regions to different tracks without altering region position. Undertones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-07-2020 08:20 PM
Changing the position of 0 sec. on the timeline lownotesinc Getting Started 4 07-10-2013 05:02 PM
Move regions between sessions: maintain timeline position cyclerec Pro Tools 9 2 03-10-2011 06:31 AM
Sync I/O TC output reflecting timeline position James Drake Post - Surround - Video 10 02-14-2007 05:02 PM
Timeline position affects performance? gwest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-04-2006 12:07 PM
