Old 01-14-2008, 07:31 AM
Jaimo63 Jaimo63 is offline
Default Pro Tools 7.4 Elastic audio tutorials...?
Are there any video tutorials going through the elastic audio features of 7.4?
I have seen the ones on the Digi web site, that Phil Jackson has done, and while they are informative, it's on a broader level.
I was wondering if any where available that really went into detail, showing real world examples, practical applications, especially using the warp markers, etc...
I'm doing fairly well with it, I think, but would love to see a seasoned Pro Tools guy using it in action, explaining WHY he/she is doing something.
Is there anything on the market like that yet?
Thanks in advance...
Old 01-15-2008, 11:27 PM
Jeff D. Jeff D. is offline
Default Re: Pro Tools 7.4 Elastic audio tutorials...?
I've been working on a title for HowAudio.com on this subject. They've posted a free preview movie on youtube that might be helpful.
Here
Hope that helps...
www.jephthastudios.com
Old 01-16-2008, 02:30 AM
chicken chicken is offline
Cool !
How would one proceed if you have an existing project and you would want it to become slower ?
By this I mean I would like to keep the drums, guitars, keyboards and bass (all on seperate tracks) but slow it down (without changing pitch an without other artifacts).
I would re-record the vocals.
Best regards,
chicken
New shoes always hurt.
Old 01-16-2008, 11:22 AM
Yes, you can easily change the whole project tempo. Including vocals!
1. Make sure all tracks are set to "ticks" mode. To change this hold down option and click on the little colored icon to the left of the word "dyn" on any audio track in the edit window.
2. Enable elastic time on all audio tracks. The easiest way is to hold down the option key and select the "polyphonic" elastic audio plug-in. You can change the drum tracks to "rhythmic" if you want, or tweak later.
3. In the edit window, go up to the tempo ruler and double click on the red triangle. That will bring up the Tempo Change dialog box. Change the tempo to whatever you want. To keep things nice and tidy, try to make this change on bar 1 beat 1 (as far to the left as you can go in the tempo ruler).
That's it! Your tracks should now play at the new tempo.
If that doesn't work, try step 4:
4. Make sure ProTools knows how long each region should be. To check this select each region one at a time and press option+5 (or select "elastic properties" from the Region menu). Type in the correct length for the region. (It really helps if you can trim your regions to an exact length in grid mode first, so that your regions are a nice round length such as 4|0|000). For example, a 4 bar drum loop region needs to be exactly 4 bars long and read 4|0|000 in the elastic properties window for elastic audio to work correctly. Do this for every region that's not changing tempo correctly.
Hope that helps,
Jeff D.
Pro Tools 10.1.2 Elastic Audio Warble rogercollege Pro Tools 10 8 12-02-2012 05:41 PM
pro tools elastic audio Steveg12 Pro Tools Express on Mac OS X 1 07-17-2012 09:50 AM
Render elastic audio alert when not using elastic audio! weird! jjboogie macOS 7 03-26-2012 09:01 PM
Elastic Audio Tutorials MSD Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-21-2008 06:52 PM
New Elastic Time tutorials from Kenny Gioia Holly73 Tips & Tricks 11 06-27-2008 11:37 AM
