Old 12-13-2007, 07:04 AM
Redhouse_Janke Redhouse_Janke is offline
Default D-Command, Preview, Glide automation
Hello. I´m hoping that somebody can help me with the glideautomation-trick.
I have just set up a song for mixing on my brand new D-command,
And I was thinking that I want to start using the glideautomation-function.
This is how I cant get it to work......
All my plugins have all parameters set to auto enabled. All tracks are set to auto-latch-mode.
Automation is set to Preview mode. In this state the DC work like an analog console and I can do a roughmix, mark the hole song and write to all enabled, to print all automation on all tracks.
So far so good. Now lets say i want to completely change the sound on the first bridge.
I loop the bridge, tweak the changes and write to all enabled. Works like a charm.
If I go out of previewmode and set automation to read, hit play......it works... two different mixes.
.......but now I want to glide the parameters from the vers to the bridge, and I cant seem to get it to work.
I mark the area from where I want to start the glide to where the bridge starts, and ......should I use
Glide to all enabled, or Glide to current. None of them seems to work.
Am I missing something?
Thankful for any help
/ Janke
Glide Automation bug in PT 10.3.4 mgoorevich Pro Tools 10 19 03-17-2013 09:09 AM
10.2 Glide Automation Behaviour moofie Post - Surround - Video 22 01-10-2013 04:44 AM
Glide Automation still not working? soundarchitect macOS 1 01-08-2013 11:17 AM
10.2 Glide Automation Behaviour moofie macOS 0 06-05-2012 03:24 PM
glide automation still works? tomcat Pro Tools TDM Systems (Mac) 5 01-27-2008 05:13 PM
