Old 04-16-2020, 09:50 PM
Top Jimmy's Avatar
Default Tap into onboard talkback mic without xmon - control cable pinout?
I apologize ahead for being snarky but why the hell hasn't anyone looked it up in a manual? In less than 2 minutes I found a pinout for the DB15. Pin 15 is mic with 8 as ground. Sheesh!
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-16-2020, 11:14 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Tap into onboard talkback mic without xmon - control cable pinout?
Not snarky at all...
Thanks for the info. I found these, which would also be helpful.
File Type: jpg Screen Shot 2020-04-16 at 11.12.20 PM.jpg (33.5 KB, 0 views)
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 04-17-2020, 05:41 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by Led View Post
Hi Chris, I believe the onboard talkback mic that is mounted in the meter bridge travels to the xmon via an unbalanced feed in the control cable. It must, otherwise how could it get to the xmon?
Cheers
Oh Yeah i guess you could try it and see, i very much doubt if the other features would work without the xmon connected, Dim, Auto-talkback etc or if the talk back button itself would wotrk without an xmon connected, but i just don't know for sure.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2020, 04:14 PM
Led Led is offline
Top Jimmy, I couldn't find it anywhere in the pdf manual...but now you've said it's there I went and found it in the pdf right towards the end...all I can say is you're a better man than I, and thanks for the effort, much appreciated.
Cheers,
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 04-17-2020, 10:38 PM
Led Led is offline
Originally Posted by Ryan Young View Post
I’m doing the same but I’m now also dealing with my Omni mic pres not adjusting. That’s a story for another post.
I’m going to be buying this and see what I can do (hopefully without breaking something!)
Ryan, I got this working, but as suspected, it's on the whole time, and the talkback button only functions with the xmon, which makes sense. It's a pretty high output and wide pickup but a little noisy. Still have to bring it up an aux channel and use the mute button same as you would with an external talkback mic without a control surface. So the only advantage is that you have a mic in the meter bridge rather than one sitting on the desk. So the wiring was Dsub pin 8 to xlr pin 1, dsub pin 15 to xlr pin 2. xlr pin 3 not connected, connecting it to pin 1 increased the noise floor a little.
Cheers
Andy Evans
www.mud.net.au
Xmon, listen mic and talkback amolin Avid S6 13 06-16-2016 07:22 PM
Give me please the 1622 interface cable pinout! PUL Pro Tools TDM Systems (Mac) 1 09-17-2013 08:36 AM
XMON Eucon Software and wiring Control-Breakout Cable moacito System 5 3 05-02-2013 08:26 PM
System 5MC and XMON Talkback Mic Help Bear Jam System 5 6 11-30-2012 10:15 AM
rs232-rs422 machine control cable pinout Ghengis Pro Tools TDM Systems (Win) 1 03-30-2005 10:39 AM
