Old 04-08-2013, 04:29 PM
JGlen JGlen is offline
Default PT 11 and any ASIO interface
Does anyone know if PT 11 will work with any ASIO interface as does PT 10?
I use an RME FF400, and I'm considering upgrading if my current interface will work.
Thanks!
ADK Quad Pro, Intel Core i7 3770 IVB 3.5 Ghz, Windows 7 64
Seagate 500G Sata 600 OS Drive, Seagate 1 TB Sata 600 Audio Drive, 8 gigs of ram, 700 watt Coolermaster Silent Pro power supply. Apollo Quad Interface, Burl B2 ADC, Dangerous D-Box, UAD 2 Duo, Avalon 737, UA 610 MK II, UA 1176 LN Hardware, Focal CMS 65 monitors, and a bunch of other stuff.
Old 04-08-2013, 08:55 PM
albee1952 albee1952 is online now
Default Re: PT 11 and any ASIO interface
Odds are excellent that any ASIO interface that works with 10, is still going to work with 11(provided the ASIO driver is compatible). Some hardware may need an update(and some companies are faster than others there). I suppose its even possible that the unsupported 002 might still work with something like ASIO4ALL(but I wouldn't count on it) Remember, any new driver is going to need to be 64 bit compliant.
Old 04-08-2013, 10:13 PM
Thanks albee. I am just concerned as Avid's site does not specifically state this, as it did for PT 10.
Focusrite interface asio error solved. Obe1 Windows 4 01-07-2012 09:53 AM
Using my Venue as an asio device - Smaart interface SteveGam VENUE Live Sound Systems 10 10-18-2010 08:04 AM
"Doesn't support ASIO interface" error mgross333 Pro Tools M-Powered (Win) 2 09-14-2010 11:29 AM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
Additional MIDI Interface when using ASIO Drivers with Reason / Propellerheads ??? georgelevy MIDI 1 03-09-2003 09:14 PM
