Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-23-2019, 09:50 AM
amagras amagras is offline
Default True or False or
I made this little survey a while ago and I would like to hear what you guys think of the results. I completely made up the first option, if there's a remote possibility that the proximity effect is not a problem in the box I swear I don't see how. The second one however...
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-23-2019, 10:05 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Default Re: True or False or
I would say both are false. But then I started out on analogue equipment, so I may know too much.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 01-23-2019, 02:54 PM
Both are false.
Proximity effect happens at the microphone(regardless of analog or digital recording). But also consider, proximity effect can be a problem, or it can be a blessing. It depends on how its used(and was it on purpose or by accident).
Gain Staging is absolutely still important, although somewhat different, especially when it comes to recording levels. (There is no reason to "slam" the input meters in any DAW because you have no tape noise to be concerned with).
Old 01-23-2019, 03:12 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Both are false... recording one ADR session will prove it.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 01-23-2019, 04:00 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
IME both false. I could be wrong, but I'm positive.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 01-23-2019, 04:59 PM
Before this thread go on I want to say that I believe the second is true, I base my opinion in this:
https://youtu.be/Ph1M3QZGku8
However I welcome anyone who's willing to convince me otherwise, I'm here to learn.
amagrasmusic.com
Old 01-23-2019, 05:14 PM
Top Jimmy's Avatar
Before this thread go on I want to say that I believe the second is true... However I welcome anyone who's willing to convince me otherwise, I'm here to learn.
Gain staging is supremely important because it begins at the preamp.
Send your session off to a top tier mixer and you're going hear about it if he has to bring relative gains into the ballpark before he even begins mixing. Proper gain staging of all the elements in the mix from start to finish makes everyone's job so much easier.
James Cadwallader
Old 01-23-2019, 05:18 PM
I have to make more clear that I'm talking about audio when its been already converted to digital (hence the "in the box in the original poll). Preamp is still analog.
amagrasmusic.com
Old 01-23-2019, 05:26 PM
Top Jimmy's Avatar
I have to make clear that I'm talking about audio when its been already converted to digital. Preamp is still analog
If you're going to narrow the scope like that, your argument becomes moot because gain staging begins at the pre amp and if you negate the analog side, you're not talking about gain staging. All you want to argue about is digital headroom without loss of resolution.
James Cadwallader
Old 01-23-2019, 05:27 PM
Then I'm right!
I understand the importance of proper gain staging but once you have everything inside Pro Tools you only have to worry not to saturate the analog algorithms of analog emulation plugins and the master/converters. That can easily be done with clip gain and the channel faders....unless you mean that once ITB gain staging doesn't exist at all
amagrasmusic.com
"A VST Wrapper is a VST Wrapper" True or False? DBK AAX Plug-ins 9 12-23-2014 09:38 AM
MIDI CC - True of False eitw Pro Tools 11 19 09-22-2014 03:45 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
New G4...false alarm.. Seller Pro Tools TDM Systems (Mac) 19 08-27-2002 06:11 PM
Pro Tools 5.1: Does it sounds better? TRUE OR FALSE??? joy4u Tips & Tricks 7 03-07-2001 11:14 PM
