Old 08-14-2004, 12:03 PM
ashish ashish is offline
Default apogee big ben & protools
Hi guys!
need help!
just bought the big ben, connections to protools which has 2 ADAT interfaces & Yamaha O2R
the O2R does have sync to wordclock in the digital i/o page and works fine, green light steady.
my problem is - how do i connect it to the ADAT i/os, i mean not the physical connections [the BNCs are there ]
In session setup, options are 'optical, digital and internal'
optical - then it wants to slave to O2R - not good
digital - it thinks i want to record from the DAT player
internal - well... whole purpose of buying the big ben is then defeated
what do i do???? if somebody has a working system like this please let me know how the chain goes and what the settings are in session setup, any thoughts, advice, chat, all welcome!
please do reply!
thanks!!
regards
Ashish Saksena
Old 08-16-2004, 07:08 AM
Default Re: apogee big ben & protools
Anybody?? Please!!
should i post it somewhere else?
regards
Ashish
Old 08-17-2004, 05:34 PM
Rezman Rezman is offline
You should be running WC to all devices except the ADAT I/O's which require Superclock (256xWC). The ADAT I/O's can recieve 256xWC from the Big Bens WC outputs 5 & 6. This is set from the front panel of the Big Ben.(Check Pages 10 & 11 of the User Guide! )
Each device should be cabled directly from the Big Ben with no daisy-chaining of devices. This will ensure the integrity of the clock is maintained.
Lastly, set your Pro Tools HW Setup to Ext Clock for each interface.
Have fun, it's a great unit
Rene Bullinga
Audio Systems Sales & Support Engineer
Protel International Technologies
New Zealand
Old 08-18-2004, 12:04 PM
Hi Rene!
thank you so much for your reply, i will set it up the way you've said, one thing if you could clear up, how do i set protools HW to external clock, because in session setup there is no option, so is there another way to do it?
please let me know!
thanks!!
regards
Ashish
Old 08-18-2004, 02:27 PM
Do this through the Hardware Setup Menu item.
Are you running PT5 or PT6?
Rene Bullinga
New Zealand
Old 08-24-2004, 03:32 AM
ver 5.1
sorry for late message i've got a bad viral,
thanks!
Ashish
Apogee AD8000 Protools 9 or 10 CHRIS AIKEN macOS 9 09-21-2012 10:09 AM
Apogee and Protools Le swalleight Tips & Tricks 2 01-20-2008 10:10 AM
ProTools not seeing Apogee XHD possible solution Andrew. D Pro Tools TDM Systems (Mac) 1 10-23-2006 12:15 AM
Apogee AD16x and Protools MartyJB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-22-2004 06:13 AM
protools HD and Apogee AD-DA 16 Brave Noise Pro Tools TDM Systems (Mac) 0 01-26-2003 12:00 AM
