Old 06-30-2013, 07:07 AM
scullionj scullionj is offline
Default Alt-menu keyboard shortcuts - Alt+F for file menu, etc.
I think that these are called alt menu commands, but maybe there's another technical name for it that'd help me find what I'm looking for.
Basically, I'm looking at how in most programs on Windows, you can press Alt + (some other keys) to access the different menus on the menu bar. Example, Alt + F usually opens the File menu, Alt + E the Edit menu, and so forth. The letter will correspond to the displayed underlined one.
I've found that at least the ones within the menus work, without using the Alt key, so if I click the Options menu, and then the N key, I get the Preferences dialog. But, trying to see if it's at all possible to press Alt + S and be given the Options menu, or other similar menus. Anybody have any experience with this?
Note: This has in part to do with my experimenting with Autohotkey. See http://audiogeekzine.com/2008/09/spe...ools-workflow/ this link. Notice that the author mentions setting up a hotkey for pulling up things like Playback Engine & Preferences. For Show Preferences, they've remapped Print Screen to invoke Alt->S->N. But...Alt->S->N doesn't even work for me?
Old 06-30-2013, 07:17 AM
Default Re: Alt-menu keyboard shortcuts - Alt+F for file menu, etc.
OK, interesting. I was messing around and realized that if I actually press the keys in completely sequential order, it works. So, I pressed alt, and let go, then pressed W, and let go, and then I had the Window menu open. So, that issue solved.
I guess now if anyone wants to use this thread to discuss different things they've done with Windows and setting up their own shortcuts using Autohotkey, or other workflow tricks? I'm all about that stuff
Old 06-30-2013, 08:28 AM
A couple of us have YEARS and multiple apps built for PT users using ahk. Shan spearheaded this back around 2004-2005 somewhere and He introduced me to it soon after.
There is a lot of issues with PT remapping keys at a registry level that makes it not possible to work inside of PT. Yes alt is one of the modifiers that will not work. a lot of creative thinking and knowing multiple ways to make any function work is necessary to use ahk. If you are wanting a more simplistic way to create shortcuts, look into a macro recorder.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 07-01-2013, 11:48 AM
Interesting, I had no idea that people were doing it. I tried a bit of googling around, but was mostly only able to come across a couple unanswered threads on the AHK forum & then that blog post that I linked in my OP. Could you recommend any starting threads or resources that might still be around for learning a bit more about the kinds of things that all of you were/are doing? Was my mistake searching Autohotkey and not AHK? Thanks.
Old 07-01-2013, 08:27 PM
I honestly dont know of anywhere. we kept it off the forum as its just not relevant and the ahk forum in many cases is about useless. we pretty much just talked on skype when we needed and spent more endless hours than I care to think about just experimenting with different ideas and I lived with the help manual open in my taskbar for seriously a couple years I think. basically come up w the idea of what you want to do, then start hammering the ahk manual, it is actually really good. Just know that PT does not play nice!!!
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 07-02-2013, 01:54 AM
Shan's Avatar
Shan Shan is offline
Many can be found in this old link in my sig. It's probably way past time I update it and add all the new stuff from over the years. There's also Steve's TRASHER, which is a complete utility app created with AHK(at least the first few versions were that I know of).
On the topic of menu items, I recommend using the PostMessage command in AHK.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 07-02-2013, 10:13 AM
Shane
Wow, I had forgot about that old thread!!!!
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 11-22-2015, 08:59 AM
joachim's Avatar
joachim joachim is offline
... Notice that the author mentions setting up a hotkey for pulling up things like Playback Engine & Preferences. For Show Preferences, they've remapped Print Screen to invoke Alt->S->N. But...Alt->S->N doesn't even work for me?
Old thread, if found when searching, hit my interest.
I am not an ahk-expert, but those things I like to do that easy way :
( // means comment )
// Setup, I/O = Ctrl Shift 1
^+1::
WinMenuSelectItem, Pro Tools, , Setup, I/O...
return
// Setup, Video Sync Offset = Ctrl Shift 2
^+2::
WinMenuSelectItem, Pro Tools, , Setup, Video Sync Offset...
return
// Setup, Preferences = Ctrl Shift 3
^+3::
WinMenuSelectItem, Pro Tools, , Setup, Preferences...
return
Maybe of help.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Keyboard access of menu commands broken in 11 b1daly Pro Tools 11 17 04-11-2016 06:20 AM
laptop shortcuts for window menu (fn key not working?) NashGtr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2010 08:54 PM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 08:30 AM
Creating shortcuts for menu objects JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-07-2006 06:35 AM
Keyboard shortcuts - duplicate menu item names jeremyroberts Pro Tools TDM Systems (Mac) 0 11-18-2005 02:04 PM
