Old 11-02-2016, 03:01 PM
Kristo Kotkas Kristo Kotkas is offline
Thumbs up soothe - dynamic resonance suppressor
I thought I'll not be buying any plugins anymore.. I demoed this for 30 seconds and it was clear, this will replace all my dynamic eq's. The only downside for me is that the latency is big and with my PT10HD system I will need to print this down, but it's worth it. Check it out! soothe
Old 08-05-2017, 10:40 PM
MixerGuy MixerGuy is offline
Default Re: soothe - dynamic resonance suppressor
has anyone else tried this plugin?
i'm PT 10 so it wont run for me.
Old 08-06-2017, 02:07 AM
Sardi Sardi is offline
Yep.
Same as above. Tried it and after 5 mins, had my credit card out.
Old 08-06-2017, 06:57 AM
WernerF WernerF is offline
Says on the site that it'll work on Mac OS 10.7 through 10.12 at 32 bit. Should work fine for Pro Tools 10.
Old 08-06-2017, 08:43 AM
No, it wont run in PT10.
They only offer AAX in 64 bit
see here - at the bottom.
https://oeksound.com/soothe/
Old 08-06-2017, 10:36 AM
Just looked again and it's a bit confusing. They mix up OS specs with format specs. One of the reasons I think that it works is because the OP seems to be using it in Pro Tools 10HD. Just re-read the opening post. I'm not at my studio at the moment so I can't check but will do later.
Old 08-06-2017, 01:35 PM
Hey Kristos, just downloaded the demo but the registration process seems a little off. I still haven't received an e-mail from them with my serial number. Do you know if they send those out by hand or is it automated like most companies these days. Thanks in advance for any advice about this.
Old 08-06-2017, 02:18 PM
Just tried it. Turns out that you're right, it's only AAX 64 bit, but you can use it in Bluecat or another AU host. Not sure how Kristos is using it in P Tools 10. He's right though, it has mega latency. You would have to print it if you use it in P Tools 10 because the latency is higher than what the 32 bit version of P Tools can handle, unless of course you run an extremely low buffer size.
Old 08-08-2017, 10:18 PM
Wow, this tool is pretty fantastic!
Great for dialogue.
Old 08-11-2017, 06:52 AM
elicious elicious is offline
It's great to see guys like Ollie,
and Dennis from Zynaptiq,
really pushing the boundaries of working in the box
by thinking outside the box.
Rather than, did I really see three new tape sims introduced last month?
Soothe is a brilliant solution to a common problem,
dealing with resonances, particularly when receiving files from home studios.
Along with another new tool that it can work hand in glove with,
called DeEdger which works on harsh transients.
These are the sort of devs we need to support and encourage
to keep them coming with their innovative ideas.
Still sad thinking about Paul Frindle throwing up his hands and depriving us of his talents.
e
ihatetyping
HTML code is On
Waves NS1 Noise Suppressor superhunter2 Buy & Sell 1 04-28-2016 11:13 AM
Waves Noise Suppressor now available Studio Dweller Pro Tools TDM Systems (Mac) 21 11-12-2009 11:37 AM
192 voltage suppressor...help pls engineering? Jack Ruston UK Pro Tools TDM Systems (Mac) 0 10-12-2005 05:01 AM
What's SO dynamic about dynamic voice allocation??? jimlongo Pro Tools TDM Systems (Mac) 0 03-14-2001 02:52 PM
Resonance Filter TDM JLEpperson Pro Tools TDM Systems (Mac) 1 10-28-2000 06:44 PM
