Old 11-12-2018, 04:28 PM
crizdee's Avatar
crizdee crizdee is offline
Default Audified U73b compressor £45 ($58) At Plugin Boutique
On special offer at Plugin Boutique right now.
Never thought i would buy another compressor but this is a stellar compressor.
The version you buy is V2 aax64 for PT 11 onwards But once registered the seriel in your audified accoount you can also download the v1 which is aax32 and works on pro Tools 10 Mac OS 10.8
https://www.pluginboutique.com/produ...-Compressor-V2
https://shop.audified.com/products
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-12-2018, 10:28 PM
AlexLakis AlexLakis is offline
Default Re: Audified U73b compressor £45 ($58) At Plugin Boutique
I have this plugin in Slate VMR and it is magically smooth on overheads.
It is one of the most CPU-hungry plugins I use.
Old 11-13-2018, 01:34 AM
crizdee's Avatar
Im not using it in Slate VMR just using it as Audified pugin and its fairly CPU efficient for me.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-13-2018, 04:18 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Cool. Looking forward to try the demo later today.
Does it have any latency?
Hopefully it doesn't.
Old 11-13-2018, 06:39 AM
crizdee's Avatar
No latency. for me anyway using V1 PT10 HD
V2 might have selectable over sampling which might add latency but don't know.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-13-2018, 09:52 AM
chrisdee's Avatar
Originally Posted by crizdee View Post
Good. Going to try it now.
Old 11-13-2018, 03:22 PM
chrisdee's Avatar
It sounds great, but its very cpu intensive. Adds 30% cpu usage with only one instance.
Old 11-14-2018, 01:44 AM
crizdee's Avatar
? I'm running about 10 in a session along with loads of other native plugs no problem.
Maybe this is in issue with V2 or are there settings for over sampling on V2.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-14-2018, 03:18 AM
amagras amagras is offline
I don't remember it being so CPU hungry, even v2. Great Vari Mu compressor, I wish it would be possible to run both v1 and 2 at the same time, I prefer the dark look of the first version.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 11-14-2018, 06:41 AM
chrisdee's Avatar
Are you on Mac/OSX or PC/Windows?
HTML code is On
Anyone know of an 8 channel ADC (not boutique!) Pete Gates General Discussion 10 03-08-2017 11:03 AM
SoundSpot Propane, 90% flash sale at Plugin Boutique amagras AAX Plug-ins 2 01-27-2017 08:36 PM
Audified GK Amplification 2 Pro Bass Amp crashes PT 12.5.2 Justin1524 AAX Plug-ins 0 07-13-2016 10:44 AM
Is it worth buying 'boutique' mic pre if only used for 003? Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2007 03:24 PM
Compressor plugin's? Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-21-2007 09:40 AM
