Old 12-04-2019, 09:37 AM
Marsdy Marsdy is offline
Default NI Maschine 2.9 separate outputs broken?
Just updated to Maschine 2.9 and in every session I load in PT Ultimate 2019.10, the separate outs are not passing audio into PT aux tracks. Was working fine yesterday with the previous version of Maschine. Maschine’s main output into the Instrument Track it’s instantiated on is working fine, just the separate outs routed to aux tracks are dead.
Any ideas? I think this has happened before with a new release but can’t for the life of me remember the solution. A long Google has proved fruitless.
I’ve tried removing the plug in and reopening it, re-routing the aux tracks all the oblivious stuff but nothing has worked.
Dave Marsden
UK
Old 12-04-2019, 11:51 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: NI Maschine 2.9 separate outputs broken?
Try standalone <check prefs>then back to plugins.
Old 12-04-2019, 01:28 PM
You mean check if separate outs are working standalone?
Dave Marsden
UK
Old 12-04-2019, 02:30 PM
DetroitT's Avatar
Follows NI’s sampler setup protocol.
Worth a try?
Old 12-05-2019, 02:36 AM
Dogbites Dogbites is offline
Yes Same Problem. Just updates Maschine MK3 to 2.9 and same thing is happening. All my sessions had separate outputs via Aux on Pro tools 12 ultimate and although the option is there in Maschine, it is not sending to the output or at least pro tools is not receiving.
Path is - Pro tools, Aux Channel, input, plugin, Maschine 2 ext. 2 or 3etc...
What used to be a simple procedure is now no longer working.
Please help! I'm screwed at the moment
Old 12-05-2019, 03:12 AM
Not just me then. It’s looking like a bug in 2.9. I’ll email NI support.
@DetroitT
I did rebuild everything from scratch in an empty session. I even watched the Maschine separate outs in PT NI support video to make sure I wasn’t missing something. It’s pretty straight forward compared to Kontakt.
PT2019.10 reinstalled the FB360 plug-ins which have previously broken Maschine in PT. Moving them to the unused plug-in folders hasn’t worked this time though.
Dave Marsden
UK
Old 12-05-2019, 03:50 AM
@DetroitT
Use the uninstaller to remove the FB360 plugins. Done.
This thing with the separate outputs not working correctly might be related to the same issue with the current version of Kontakt 6. You can assign separate outputs for each instrument in Kontakt but audio is not passing to separate tracks in PT. NI knows about it and has replicated it. No ETA on the fix though.
Jack
QAPLA!
Old 12-05-2019, 04:36 AM
OK it’s a known issue and there will be a fix next week.
The same issue in Kontakt is already fixed apparently.
Dave Marsden
UK
Old 12-05-2019, 05:31 AM
Actually the Maschine fix is in the coming weeks as mentioned in this thread: https://www.native-instruments.com/f....364079/page-2 in post #27 by an NI person. But at least they acknowledged it and a fix is in the works.
Jack
QAPLA!
Old 02-12-2020, 12:18 PM
XJENSEN XJENSEN is offline
Has this been fixed yet?
Outputs configured in I/O setup not available to select as track sends/outputs Stuart@YM Pro Tools 12 5 03-21-2016 07:44 AM
Broken light XLR connector and broken is iLok USB port victorbraga98 VENUE Live Sound Systems 2 09-28-2015 10:48 PM
Native Instruments-Kontakt 5-Abbey Road Modern Drummer-Separate Outputs to PT11 martinaston AAX Plug-ins 14 11-28-2013 11:19 PM
Routing to multiple outputs from one source broken? bleen macOS 4 11-19-2013 10:54 AM
Fried Outputs on MBox 3 Pro ? Broken ? TheFirstThird 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-20-2013 06:49 PM
