Old 03-11-2020, 11:30 AM
atticmike atticmike is offline
Default Globally trim down to -6 dBfs?
Howdy there,
I've seen that it's recommended by my converter's manufacturer to trim down the digital input to -6 dBfs.
Is there a way to do it globally on Pro Tools without having to set it up in a session all the time?
Old 03-11-2020, 12:20 PM
Default Re: Globally trim down to -6 dBfs?
Here is a couple of options:
1-Enable the ALL group>show volume and drag everything down 6db(after doing that, disable the group and restore AUX tracks volume, assuming sends are POST-fade)
2-Open the TRIM plugin, set it to -6 and then set the plugin to default to user setting. Then insert TRIM in the last slot of every track(then remove or bypass TRIM on AUX tracks). I built TRIM into all my session and track templates, but in bypass mode. When I finish tracking and am ready to mix, I enable the entire row of TRIM plugins with the option command and the entire mix drops 10db(my setting) while maintaining the same balance
Old 03-11-2020, 01:17 PM
ya that's what I do on the bus, I just need -6 for monitoring level, I wish there was a global trim for monitors so you're not slamming the distortion which occurs close to 0 dBfs.
Old 06-08-2020, 09:59 AM
Would be nice if you could trim the IO down...
Gesendet von meinem SM-G965F mit Tapatalk
Old 06-09-2020, 06:24 AM
JFreak's Avatar
JFreak JFreak is online now
Make the Master Fader of your output visible, turn down -6, done.
Janne
Old 06-09-2020, 06:30 AM
noeqplease noeqplease is offline
Location: Los Angeles, CA, USA, Planet Earth, Solar System, Milky Way Galaxy
Just do it at the converter. Does it not have trim pots of other level pots on it? Then all your input levels are always where that manufacturer suggested they be at.
If your converter has no way to trim to the level they recommend, then they are dunces. LOL.
Nick Sevilla
nick@nicksevilla.com
Old 06-09-2020, 06:32 AM
JFreak's Avatar
That would affect all sessions. Sure if you have a one trick pony that could work but I am thinking it is much easier to drop levels on a session level
Janne
Old 06-09-2020, 09:12 AM
Yes which is what the manufacturer of the converter recommends. This is for the converter not the session...
Nick Sevilla
Old 06-09-2020, 09:15 AM
JFreak's Avatar
It would not make any difference. If your converter drops -6dB with session full scale, it is just the same if session drops -6dB and converter is full scale. I prefer the latter but whatever works for you.
Janne
Old 06-09-2020, 11:05 AM
True but it would be part of my session template and I wouldn't run into something internally that Pro Tools might add. Simple trim number on the IOs, it would also allow you to trim send and returns.
Can I use a FX Loop Globally? PatriotsBiker Eleven Rack 3 12-29-2011 03:02 PM
Structure - transposing pitch globally Farmer Dave Virtual Instruments 3 01-09-2011 04:49 PM
turn off voices globally in PT? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-07-2005 10:21 AM
how do i globally disable monitoring? stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2005 07:30 AM
Anyone know what "DAW WDM Map Buffer Globally Fail rloproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-26-2004 04:29 AM
