Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-04-2019, 06:39 AM
atticmike atticmike is offline
Default Pro Tools' engine is a bottleneck?
Hello guys,
Can it be that Pro Tools' engine is limited to a certain internal headroom? I have a powerful computer but can't even go beyond 30% CPU load before tells me that I'm allegedly running out of native power and should deactivate some plugins...
Old 02-04-2019, 06:56 AM
Emi's Avatar
Emi Emi is offline
Default Re: Pro Tools' engine is a bottleneck?
Interne al headroom has nothing to do with CPU power. Could be anything that causes the issue. Did you do all the tweaks Avid recommend?
Mac Mini late 2012 i5 | Mac OS Catalina 10.15 | Motu 16A | Motu 828ES | Pro Tools 2020.5 Native
Old 02-04-2019, 07:27 AM
dankin dankin is offline
What computer are you using? On my MBP I would be bombarded with 9173s once I got above 30%. Since I turned off turbo boost, my errors went way down and I run it 60-70% sometimes on large mixs without issues.
2018.3 HD, MacPro 5.1 12core 3.46, 24gig ram, OS 10.12.6, 2014 MPB 2.8, OS 10.12.6
Old 02-04-2019, 08:48 AM
miul68 miul68 is offline
Many people complain. Many people give the same answer.
My story is this one: in the last six months, with the same computer and the same plugins, I switched from S1 to Reaper and then to PT. Neither with S1 and Reaper I’ve experienced so many trouble as described by Atticmike.
Not even close. Now, the tech guy might say that is absurd to make comparison as PT uses aax and so on.
Although, what is a fact stays there: never in those months I’ve had the problems I had with PT in 40 days.
Can't load editor if Pro Tools is already running Fuzzyc Eleven Rack 2 03-12-2017 03:49 PM
Editor won't load if Pro Tools is running Fuzzyc Eleven Rack 9 11-06-2016 03:37 AM
Pro tools running out of CPU power AAE-9173 ccapretta macOS 4 12-07-2015 07:27 AM
" You are running out of CPU power. Reomove some Native Plug-ins or increase the CPU soemoehtet Windows 3 09-02-2014 11:45 AM
Error message!! You are running out of CPU power. Remove some Native plug-ins... Jmissy87 Pro Tools 10 8 06-17-2013 06:51 PM
