Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 07-28-2018, 04:05 PM
atticmike atticmike is offline
Default PT 2018's engine very limited?
Hello there,
I'm running PT in native and I have a very capable CPU (10 core i7) but even though my CPU is running at 15% load, PT at buffersize 1024 just craps out (starts to sound bit-distorted) and I have to reopen the session. Seems like they've been running with the same headroom since PT10? I have only used 15% of my CPU resources and the session gives in.
Old 07-28-2018, 04:11 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default Re: PT 2018's engine very limited?
You should be able to run fine with a 10-core i7 and a 1024 buffer size. I am able to get things done on a 4-core i5 at 256 buffers, but I have to freeze some tracks. Is it possible that there is a plugin that is going haywire?
Old 07-28-2018, 05:00 PM
jeam25's Avatar
jeam25 jeam25 is offline
Originally Posted by atticmike View Post
Hello there,
Can you describe more in deep your session ?
- Jesus Alvarado -
Keep the volume UP !
Old 07-28-2018, 05:06 PM
BScout BScout is offline
Hello there,
What is your audio interface? Your issues more likely lie with that (drivers/hardware).
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 07-30-2018, 03:19 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Yes. I would look into that first.
What VI's and plugins do you use?
Old 08-01-2018, 04:54 AM
chrismeraz chrismeraz is offline
The problem is not with PT. I could record 16 tracks simultaneously at 512 sample buffer on a 10-year-old i3 processor. I upgraded my rig this year only because I needed a Thunderbolt connection.
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 08-21-2018, 12:36 PM
stevenengle stevenengle is offline
Hello, hoping someone has a suggestion:
In the last couple days something has gone wrong with either PT and/or plugins, and I cannot play a song without a "Pro Tools ran out of CPU power. AAE -9173" error. I'm running Windows 10, Intel i5 3GHz with 32GB RAM, and the CPU level in PT never goes above 15% when I get the error.
I found this comment interesting > "Is it possible that there is a plugin that is going haywire?" How can you tell if a plugin has gone "haywire", and what can be done to fix it?
These are the main plugins I'm using if anyone knows of known problems:
> East West: Ministry of Rock 2
> IK Multimedia: AmpliTube MAX
APPRECIATE any help to get ride of these errors so I can get back to work - THANKS!!
Steve
Old 08-21-2018, 12:40 PM
amagras amagras is offline
Increase the buffer size
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 08-21-2018, 12:54 PM
Yep, been trying that, but just tried it again and got the same error (see screenshot). These were my settings:
H/W Buffer Size: 1024 Samples
> Dynamic Plug-in Processing
Cache Size: 8 GB
Old 08-21-2018, 01:08 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by stevenengle View Post
... How can you tell if a plugin has gone "haywire", and what can be done to fix it? ...
Make sure plugs are up to date. How? Determine the exact build/version of each plug. Contact each plug company you installed (not just the plugs in use), and verify compatibility of the exact version plug/exact version PTools/exact version OS.
Also, make sure to do all Avid recommended system optimizations.
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.3 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
PT 2018.1 "video engine unable to stop" will__ward Pro Tools 2018 15 04-07-2019 01:48 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
PT 2018:1 - video engine not working (for some) noiseboyuk Pro Tools 2018 13 04-05-2018 08:21 PM
Pro Tools 2018.1 - Video Engine failing to load (Windows 10) Lana Banana Pro Tools 2018 2 02-08-2018 08:26 AM
PT11 Limited Playback Engine Option Hadassah Pro Tools 11 1 12-18-2013 10:40 AM
