Many Kontakt (or xpand) instances. Instrument input disconnection
Hi everyone.
I use PT for composing music for media. Lately (with the track folders) I started to make my templates straight in protools. My orchestral template is about 250 tracks. One kontakt instance for each family or library. Sometimes (randomly) all the INPUT in the INSTRUMENT TRACKS get disconnected from their respective kontakt. (grayed out) My guess is that PROTOOLS creates an unique secuencial ID for each instance and sometimes if the kontakt tracks are not loaded in the same order, the IDs change (for some reason) making the INSTRUMENT INPUT inexistent. I read that many people has a similar problem. Is there any solution ? It is possible to NAME each instance of kontakt instead of getting that secuencial number ?? or my only option is to host all the kontakt in VEP ? THanks! Dan ZLotnik |
Re: Many Kontakt (or xpand) instances. Instrument input disconnection
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Kontakt has 16 outs as default in all possible plugin format.
Each output is assigned to a different instrument track (in the INPUT of the track) It works great but sometimes the input gets disconnected. Weirdly enough the MIDI out keeps the connection to the right kontakt instance and channel. |
PT's dual low latency buffer, 110 instances of Kontakt 'n stuff. | Marsdy | Pro Tools 12 | 50 | 06-07-2017 07:13 PM |
Multiple instances of Xpand!2 | lgreen100 | Pro Tools 12 | 9 | 10-11-2016 08:26 AM |
How many instances of Kontakt can you run in the new pro tools HD 11? | Meccanizm | Pro Tools 11 | 5 | 04-10-2013 11:42 AM |
How many Xpand instances… | muzak13 | Virtual Instruments | 3 | 06-01-2007 04:24 PM |
Instrument Tracks & instances of instruments | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-04-2006 02:34 PM |
