Digi003 Left/Right Outputs Reversed
Last night was my first time using my new Digi003.
It performed beautifully with the exception of the left and right outs being swapped. At first, I thought I'd plugged in my monitors backwards, but it's in the headphone outputs too (and yes, my headphones were on correctly, thanks). I wasn't sure if it was the Digi003 or perhaps something had changed when I upgraded to 7.4, but when I opened the session this morning on my MBox 2, everything worked correctly. So is there some hardware setup that I'm missing? Has anyone else experienced this? |
Re: Digi003 Left/Right Outputs Reversed
I'm quessing that changing from a MBox to the 003 that something got reversed in the I/O... You might want to set the output to the default settings in the output section in the preferances.
If its just one session I would suspect something in that sessions busses, if its all sessions I would suspect something in the Prefs. I can't say as I have had this happen so these are only quesses on my part. Hope that helps.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Check your IO Setup.
Rail
How to use outputs 1-2 on Digi003 without getting main mix? | se.audio | Tips & Tricks | 10 | 12-21-2020 09:16 AM |
assigning outputs to get sound out of my Digi003 | kckel | FireWire & USB Audio Interfaces (Mac) | 3 | 05-18-2013 08:13 AM |
Digi003 Left/Right Outputs Reversed | Podgorny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2008 09:21 AM |
Outputs reversed | Sparks | Pro Tools TDM Systems (Mac) | 1 | 07-22-2003 03:27 PM |
Left & Right Speakers Reversed? | Mety | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-06-2003 03:52 PM |
