Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 02-06-2012, 06:48 PM
DJKeys's Avatar
DJKeys DJKeys is offline
Default MBox Pro 3 Tuner Issue
I have a guitar plugged into Line 2 of the unit. Everything seems to be working fine, I have signal into my Eleven plugin in PT9, I can see and hear the signal coming in and going out of the Mbox pro the way I have configured, but there is no signal into the Tuner when I open that window. It is a minor annoyance, but it would nice to be able to use the tuner. I didn't find any instances of this issue here. MBox pro is working fine otherwise.
System is below, any ideas? Thanks-
-dj
iMAC 3.2GHz 6-core i7
250GB SSD (internal)
1TB SSD (external)
16GB RAM
OSX 10.14.5
PT 2019.10 (last one)
Waves Gold/RenMaxx v11
iZotope Ozone 8
Focusrite Clarett 8Pre
Nord Stage 3
Nord Lead A1
DSI Mopho X4
Old 04-07-2012, 12:51 AM
Delianguy Delianguy is offline
Default MBox 3 pro guitar tuner - can't access it
Hi everyone,
I have never been able to access the guitar tuner from my MBox 3 pro by simultaneously holding the dim and mono switch as instructed in the manual. Has anyone else had this problem? Am I doing something wrong?
Thank for any help you might be able to give!
Old 08-22-2012, 09:55 AM
scon777 scon777 is offline
Default MBox3 Pro dsp effects
How do I get the dsp effects to work on my Mbox3 pro? Do I have to be running PT for this to work? Trying to simply put effects on Mic 1 input...don't hear any effects even though they are turned up on the control panel? Must be doing something wrong?
Thanks
Old 08-22-2012, 10:25 AM
serio serio is offline
Default Re: MBox3 Pro dsp effects
Make sure the "FX Returns" knobs, located under the master volume, are also turned up. You can leave these at full gain and just adjust the individual channels' knobs.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 08-22-2012, 10:30 AM
Thanks
Yes...they are turned up?
Old 08-22-2012, 10:51 AM
Hmmmm.....
Have you double checked that the mix that you are adjusting is the one you are listening to?
Say for example maybe you are adjusting "stereo mix 1" or something when you are monitoring through headphones A that are set to "stereo mix 5" or any other stereo mix.
Old 08-22-2012, 12:53 PM
Yea...I just have 1 mic plugged into XLR Chan 1...I'm getting audio...even able to record and everything...but do not hear any effects coming from the MBOX? Outputs 1/2 has speaker next to it...Stereo Mix 1...Headphones A set to Stereo Mix 1? FX Returns turned up....Volume on Effects turned up under Effects section on control panel as well as for Channel 1? Thanks for your input...this is driving me nuts...:)
Old 08-22-2012, 03:07 PM
I'm stumped. Make sure you are using the latest drivers:
http://avid.force.com/pkb/articles/e...nload/en375655
I'd install the unit on another computer and see if the DSP still does not function. If not, I'd return it or contact Avid. Can you give some system details? Also what effect are you trying to use?
Old 08-22-2012, 03:54 PM
Thumbs down Re: MBox3 Pro dsp effects
Well..just got off the phone with Avid...they don't know either...weird...he did mention it might be a Mountain Lion issue? I'm grabbing an older version of the OS I have as a spare and am going to try it with that to see if it works...if not...back to Avid support...thanks for your help....
Old 08-22-2012, 04:22 PM
Ok. Let us know what happens, as this might be useful info for mbox pro users interested in upgrading to Mountain Lion.
tuner not working on mbox pro tdstudio macOS 5 10-25-2012 08:28 PM
Tuner on MBox Nick@KNR Windows 1 09-29-2012 07:37 PM
MBox 3 pro guitar tuner - can't access it Delianguy General Discussion 0 04-07-2012 12:51 AM
BF Essential Tuner issue jgehring 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-09-2007 11:44 AM
